Windage tray
Old Nov 6, 2022 | 06:15 PM
Kitttransam's Avatar
Car: 87 trans am gta /89 chevy corvette
Axle/Gears: 3.27 / 3.07
Windage tray
Ok so I’m building an engine for my GTA. Now question is. I got the 1557558 oil pan. Now do I need a windage tray for this pan? Has a baffle built in. Did f body cars come with the windage tray? I’ve rebuilt a corvette motor before and it had that tray. The tray available to buy is made for the corvette pan. Or so the info I seen says.
Old Nov 6, 2022 | 06:54 PM
NoEmissions84TA's Avatar
Re: Windage tray
This oil pan? It has its own tray. A bolt-in, factory or aftermarket windage tray, attaches to main bearing cap studs. Are you planning to use studs?
Old Nov 7, 2022 | 01:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Windage tray
The Moroso pan on my race engine looks similar to that but under the windage plate, mine also has trap doors which restricts the oil movement from going to the front of the pan during braking. I also have a plate at the rear which restricts the oil from going up the back of the pan during hard acceleration.
The goal is to get the oil from the engine back into the sump as quickly as possible and keep it there so that the pump doesn't run dry during whatever type of driving you do.
Do not add restrictors/screens in the lifter valley to force oil to the front of the engine as this delays the oil getting back into the pan.
For my race engine I have 2 modification to make sure there is oil in the sump at all times.
First I use an oil accumulator. If oil pressure ever drops below the lowest pressure I have in the accumulator, the extra oil in the accumulator gets pushed into the engine until the pump makes enough pressure to refill the accumulator. Circle track racers really need this because of the constant g-forces pushing the oil up the sides of the engine will cause oil pressure to fluctuate a lot.
Second, for my engine spinning to 7000+ rpm during a 1/4 mile pass, there's a lot of oil under the valve covers that has to flow through the openings in the head, down into the lifter valley then back into the sump. I did a modification and installed fittings on the back of both valve covers and on both sides of the oil pan and connected them with hoses. This gives the oil a direct path from under the valve cover directly to the sump.
For a street car, these types of modifications are overkill. A basic oil pan built in windage tray/baffle like pictured above is more than enough. It's when you start driving in a more aggressive manner that oil control becomes more of an issue. If you want to autocross then you might want to do a few minor upgrades.
Old Nov 7, 2022 | 10:04 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Windage tray
Is this your pan Kitttransam?
https://www.summitracing.com/parts/NAL-12557558
Old Nov 8, 2022 | 08:15 AM
Re: Windage tray
yeah that’s the one I got. Am I crazy or is a separate tray not needed with that pan?
Old Nov 8, 2022 | 09:52 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Windage tray
Looks like a factory Vortec pan design. Those use an abbreviated windage tray in the back of the engine.
Old Nov 8, 2022 | 12:52 PM
Re: Windage tray
What does that one look like?? Is it different than the only one available to buy?
Old Nov 8, 2022 | 09:58 PM
Re: Windage tray
I got the milodon tray to work. Made some mods to it. Although I wonder if I should trim the sides of the tray like it was before cutting.
Old Nov 11, 2022 | 04:46 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Windage tray
GM has at least 4 trays for the small block available alone. The aftermarket has dozens more.
1bad91Z
Jul 24, 2010 12:58 AM
mw66nova
Apr 7, 2010 12:04 PM
timespy
Mar 25, 2010 03:37 PM
five7kid
Sep 22, 2009 08:52 PM
