Smog/Air Pump Removal
Old Nov 7, 2022 | 07:32 PM
jbrooks6104's Avatar
Car: 1987 Iroc-z
Engine: V8 305 TPI
I'm wanting to remove the air pump to free up room in the engine bay. From what I've read it's not needed other than for emissions which isn't a thing in South Carolina.
On my engine there is only one belt that goes from the air pump to the front of the water pump. Would it be safe to just remove that one belt and not have any issues?
Old Nov 7, 2022 | 08:36 PM
Reddragon88gta's Avatar
Engine: 5.7 L98
Re: Smog/Air Pump Removal
On your set up it could literally be that simple, I would also pull the pump and remove the AIR tubes from the exhaust manifolds to really free up some space. Just be sure to use the correct plugs for the manifolds, Edelman number 120500 will work great. The electrical connections and solenoids are easy to remove as well. The hardest thing to remove is the pipe that runs along the back of the motor but leaving that in place is not a huge deal as its not really visible.
After deleting all that it really cleans up the engine bay and makes it much easier to change spark plugs and work in there.
Some guys mention changing the tune for AIR delete but many have not and had no issues, you can research it on here but I would not tear into the tune unless you wanted to ditch EGR as well .
Old Nov 8, 2022 | 06:21 AM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
You might want to search the threads. This topic has been covered at length. Cheers!
Old Nov 8, 2022 | 12:23 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
I have searched the threads. I just wanted to know if it was as easy as taking that 1 belt off. Thanks for the tip
Old Nov 8, 2022 | 07:28 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
Passenger side
Passenger side
Deivers side
Got the air pump out. These parts have to come out and plugged correct?
Old Nov 8, 2022 | 07:39 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
They have to be plugged at least. Use flare nut wrenches, penetrating oil, and heat.
Old Nov 8, 2022 | 07:44 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
I'm trying to remove it all. Do you know a way to remove the pipe that wraps around the back of the engine?
Old Nov 8, 2022 | 08:18 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
It's tied into the ground nut on the passenger side. I got it with a flex head ratchet and shallow socket. I'm not sure if the profanity helped but I did sprinkle it in there.
Old Nov 8, 2022 | 08:25 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
Profanity always helps lol. Was it easier to get from underneath the car or top?
Old Nov 8, 2022 | 08:47 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Top, it's on the back of the head. This photo is the driver's side but same location on the other side to give you some idea:
Old Nov 9, 2022 | 06:31 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Even if you pull that bolt its kinda wedged in there... I think it mightr / will be necessary to pull out the distributor to make it easy....est.....
I gave up and left the pipe in there lol
Remove the pipes from the manifolds and plug them for sure.... it makes spark plug removal SOOOOOOOOOOOOO much easier
Old Nov 9, 2022 | 07:41 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Yep. I can get to all 8 from the top...
Old Nov 16, 2022 | 05:50 PM
1983LU5TA's Avatar
Car: 1983 LU5 Trans Am, 1967 Chevelle
Engine: LU5, LSx
Transmission: 700R4, 4L60E
Axle/Gears: 3.73, 3.73
Are you interested in selling your smog pump? I am in need of one for my LU5.
Old Nov 19, 2022 | 04:33 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
I'd be willing to sell the smog pump. It's still in working condition.
Old Nov 19, 2022 | 04:36 PM
1983LU5TA's Avatar
Engine: LU5, LSx
Price?
Old Nov 19, 2022 | 04:40 PM
Car: 1987 Iroc-z
Engine: V8 305 TPI
$100 plus cost of shipping
Cambird Z/AM
Dec 12, 2015 06:31 AM
K. E. Christy
Sep 22, 2011 10:36 AM
FlippindaBird
Jan 11, 2009 09:39 PM
concretecowboy
Apr 19, 2004 08:40 AM
Red25thRS
Mar 24, 2004 10:17 PM
