Wheel bearings
Old Dec 22, 2022 | 08:23 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Wheel bearings
Hello. I am looking at replacing the inner and outer wheel bearings for my 1991 Camaro z28 with rpo g92. What is a good set to go with that are compatible with my car, and the part numbers?
Thanks in advance
Old Dec 22, 2022 | 10:02 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Wheel bearings
Assuming fronts, are they bad? I would disassemble, clean and check them 1st. Most likely repack and keep originals., with new seals.
especially with The quality of parts these days.
Old Dec 22, 2022 | 10:54 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Wheel bearings
I recommend Timken. You can get them on Rockauto right now actually.
Old Dec 22, 2022 | 11:47 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Wheel bearings
Timken and National are solid, SKF is also probably fine. Part numbers are the fun part you get to look up.
Old Dec 22, 2022 | 01:42 PM
Engine: 305 cid
Re: Wheel bearings
Sorry, I should have specified that it's for the fronts. The originals wheel bearings are no longer. I replaced them back in 1996. I had all the pads and rotors changed in 2019. I'm thinking the mechanic reused the wheel bearings. I'm hearing what I think is a bit of a hum noise coming from the passenger front.
Old Dec 22, 2022 | 01:44 PM
Engine: 305 cid
Re: Wheel bearings
Yes. Some said timken is good. Do you know that part numbers that are compatible with my car?
Old Dec 22, 2022 | 02:27 PM
Car: 1983 Z28
Re: Wheel bearings
I don't, but if you go to rockauto.com you can pull up an entire list for a 91 z28
Old Dec 22, 2022 | 04:56 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Wheel bearings
If the bearings are shot, the outer bearing races that are pressed into the rotor hubs are going to be shot too. The new bearings will come with new outer races. You will either need to pound the old races out of the existing rotors with a punch and a hammer and drive the new races in, or just replace the rotors. The new rotors will come with new races already installed. Rotors are pretty cheap vs. your time screwing around with replacing the races.
Wheel bearings/seals, rotors and pads are pretty inexpensive for these cars. I have always replaced pads, rotors, wheel bearings and seals as a set. No sense in screwing around with mixing new and old parts for the minimal cost savings and then dealing with issues later.
Old Dec 22, 2022 | 05:02 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Wheel bearings
I agree, get two birds stoned at the same time.
Evilokc
Dec 14, 2018 10:15 AM
sonu1975
Wheels and Tires
Jun 4, 2015 10:53 PM
Mr Froman
Oct 5, 2010 04:48 PM
Mike_84
Mar 26, 2006 03:11 AM
