Throttle cable end snapped/replaced - crank no start
Old Jan 11, 2023 | 12:22 AM
leetlordz's Avatar
I have a 90 Camaro RS that is my daily driver.
As I was giving it some gas to get up to highway speed it died mid drive.
We found that the Throttle cable end had snapped, so we ordered the replacement.
Since replacing end the car cranks but wont start.
It looks like all of the elctrical components are working, headlights, accessory etc.
Could this be sensor related? Any ideas?
Old Jan 11, 2023 | 11:01 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Throttle cable end snapped/replaced - crank no start
At this point, it could be anything.
Any ideas?
Start with basic troubleshooting. Check for: spark at the plugs, injector pulses at the injectors, and fuel pressure. The results will give you some direction from which to proceed.
Old Jan 11, 2023 | 11:31 AM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
The snapped cable should not have shut you down. You'd be stuck at idle. Did something let go on your throttle body?
zenish
Nov 30, 2014 05:57 PM
TPI-Formula350-
Apr 23, 2011 11:06 PM
wiggin
Dec 19, 2009 05:20 PM
SS ninja
Alternative Port EFI Intakes
23
Apr 29, 2009 11:12 AM
dacuma
Jun 8, 2002 11:30 AM
