Anyone enlarge the stock runner gaskets?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I ordered TPIS runner gaskets. Selected 2 day shipping. That was last week. They still haven't moved. This of course is holding me up. At this point I'd like to order the Felpro gaskets and open them up to meet the Edelbrock runners and lower. Have any of you had success with this? There are literally no other options. The Mr Gasket 146 is non existent. No one can tell you when they'll ship. So I'm kind of stuck.
Engine: 4++,350 & 305 CIs
Re: Anyone enlarge the stock runner gaskets?
I've done it in a pinch, since there's metal in the stock type gaskets, i used a cast iron bit on a air powered rotary tool.
I have to make custom runner gaskets for my intake and use MR Gasket 77B gasket sheets ($14.19 shipped). I can confirm it is the same gasket material used in the MR Gasket 146 gaskets.
https://www.ebay.com/itm/354434063687
I use a small X-Acto razor knife (a small breakaway blade utility knife doesn't work as well, but will work if you already have one) to cut the runner openings. If you're careful and go slowly you can make a clean cut, although it might take more than one pass around to cut all the way through. I've seen some cheap looking China made sets of round hole cutters that included a 45mm (1.77") punch for around $15 that MIGHT make things a little easier, but if you're not making a lot of gaskets it's probably not worth taking a chance that they would actually work.
The biggest problem for me when making the gaskets were cutting out the bolt holes. I ordered a relatively nice set of gasket making punches for $22 since I have to make custom gaskets for my intake and headers. However, if all you plan on making is one or two sets, eBay has a hollow punch set that looks like they would work OK for $7.75 shipped. I can tell you from experience, even if you can only get one set of runner gaskets out of them, it'll be worth the 8 bucks - lol
https://www.ebay.com/itm/374410961766
Anyway, thought I would share in case making your own gaskets (at $22 and your time) would be an option for you.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Great info. Thanks! I can get the 145 set. If it's the same material as the 77B I'll just open those up since there's no metal and the bolt holes and shape are already there.
When making your own gaskets, you draw out all the gaskets on the material, then use the punch for all the bolt holes, then cut out the all the openings, and lastly you can use sharp shears to separate and finish off all the individual gaskets. However, the shears need to be really sharp, especially if your cutting close to the openings or bolt holes.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
You don't have to hit it hard enough to cut the material all the way through, either. Just enough to cause a "perforated" effect, then tear out the pieces that need to go (runners, bolt holes, EGR hole, etc.).
A gasket like that needed for one side of the TPI should be able to be "banged" out in under 5 minutes.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Meh. I grabbed the Felpro and took a Dremel to it. Didn't have to do much. The runners are installed
Opened up some stock type gaskets to fit my SLP runners & ported base. Not that I need to at the time, still got the SLP paper gaskets in my gasket tote But I preferred the metal core stock type. Used a drum sander on my air grinder if I rem right, might of used a carbide burr but can't rem if i had to.
Car: 1987 Z28 IROC
Engine: 6.2L
If it helps anyone, years ago I traced out the Mr. gasket 146 set on gasket paper and put it on the shelf. Not sure how I could create a digital pattern though.
Car: 1989 Camaro IROC Z
Transmission: 4L60
Axle/Gears: 2.77 G80 9 bolt
Arizona Speed & Marine sells a nice set of oversized gaskets and they actually ship. I had to do a chargeback on TPIS last time I tried to order gaskets from them. I never got a response from multiple emails and phone calls so I called the credit card company. I hope you have better luck.
