timing issues
Old Mar 1, 2023 | 12:43 AM
TreyFiggs's Avatar
Car: 1983 Berlinetta & 1989 V15 Burb
Transmission: 700r4😪😪
timing issues
car is a 1983 Berlinetta with the 305 all stock but the edelbrock 1406 carb. the other day i took off cap to check what points and rotor looked like....short story, i put the cap back on and somehow my **** is like this...but after lining it up you can see the pulley mark is right but rotor isnt pointing right....ugh
Please help
Old Mar 1, 2023 | 02:59 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: timing issues
What is the problem we are solving here? Is the rotor just not pointing to where you think it should point, or is it running poorly, or what?
Old Mar 1, 2023 | 08:44 AM
TreyFiggs's Avatar
Re: timing issues
all of the above lol.... when I'm at tdc my crankshaft mark is like at the 2 of 230 position....I can't get it to start.....I tried getting my timing mark right but but I can never get both the mark and the rotor in the right place at right time
Old Mar 1, 2023 | 12:52 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: timing issues
Ok, it sounds like you need to re-stab the distributor such that it falls into place with the rotor pointing towards #1 with cyl #1 on the compression stroke at tdc. If the distributor doesn't fall in, the oil pump slot is probably not in the right place and you can turn it with a long flathead screwdriver or a distributor shaft with no gear.
Old Mar 1, 2023 | 05:59 PM
TreyFiggs's Avatar
Re: timing issues
I'm lost but I'll figure it out.... thank you.... what I don't get is how it got off... it was itne beforeand all I did was take the cap off
Old Mar 1, 2023 | 06:00 PM
TreyFiggs's Avatar
Re: timing issues
so I take the distributor out, turn until I have tdc then put it back in? What if my crankshaft mark isn't right?
Old Mar 1, 2023 | 06:38 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: timing issues
We were only talking about turning the oil pump. If you haven't moved the distributor and it used to run well, I would not pull the distributor.
Use a piston stop to find true tdc, compare that with your timing marks if you suspect the balancer has shifted.
Old Mar 1, 2023 | 07:02 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: timing issues
I had to scroll back up to recheck the original complaint.
So you never actually pulled the distributor out of the engine or turned it at all. You only removed the distributor cap and rotor.
First of all, where the #1 plug wire is on the distributor means nothing as long as all the plug wires reach the plugs. It's just a lot easier when #1 is in the 5 o'clock position.
Since you never changed the position of the rotor in relation to the timing the only thing you need to check is where each plug wire is. With #1 plug wire at the 5 o'clock position, the order of rotation is clockwise and the firing order is 18536572. It's very easy to mix 5 and 7 up when putting plug wires back onto the cap.
If the engine doesn't start, rotate the plug wires around the cap one position instead of rotating the distributor and changing the original timing.
Old Mar 3, 2023 | 10:54 PM
TreyFiggs's Avatar
Re: timing issues
so I redid the tdc and it finally started I set the timing 6°, plugged the 4pin plug back in and although it starts, it seems to struggle to start and seems when i hit the gas and let off it drops down and feels like it's gonna die....
Here's a question... original owner swapped the stock catnip to a 1406 edlebrock, but now that it's a mechanical carb should the distributor be a vacuum advance rather than the stock one that the computer runs?
Old Mar 3, 2023 | 10:56 PM
TreyFiggs's Avatar
Re: timing issues
And AlkyIROC thank you for your help....I truly appreciate it
2QUIK4U
Jun 16, 2015 06:44 AM
richw40
Apr 4, 2013 09:32 AM
kingnothing23
Dec 26, 2003 09:53 PM
twitchm80
Feb 2, 2003 06:49 PM
Hype
May 1, 2001 11:43 PM
