Curiosity
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Curiosity
Why does the bbk 52mm throttle body have a upper hole above the iac passage that goes nowhere? It just dead ends into plenum.
Engine: 5.7 l98
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Curiosity
Upper passage goes to large side port on the Throttlebody. Pcv vent hose
Engine: 5.7 l98
Engine: Lb9
Transmission: M20
Re: Curiosity
If you have a hole straight through the Throttlebody that’s a major potential vacuum leak if the gasket isn’t sealing it.
Engine: 5.7 l98
Re: Curiosity
Engine: Lb9
Transmission: M20
Re: Curiosity
If this is an old bbk take off the cover. Pretty obvious where the port goes. This is for crankcase vent and yes the passage goes out the right side of the tb.
Engine: Lb9
Transmission: M20
Re: Curiosity
Engine: 5.7 l98
Engine: 5.7 l98
Engine: Lb9
Transmission: M20
Re: Curiosity
That’s a huge vacuum leak, I’d call bbk and inquire. Could be defective
Engine: Lb9
Transmission: M20
Re: Curiosity
Should just look like this with iac and ported vacuums passage only.
Engine: 5.7 l98
Engine: 5.7 l98
Engine: 5.7 l98
Re: Curiosity
Interesting, don't feel like digging mine out atm but I'll prob epoxy it up when I smooth things out. Hate how they leave things so rough on the newer version but I got a good deal on it.
Casting was used for LT's and maybe other apps, so all could get the same basic machining.
edit: LOL actually just remembered that I bought some stuff to deal with that hole already, Think I got some alum bar stock and was gonna green loctite it in. Funny how I forgot bout that, it's been a few years since I looked it over But now I deff rem planing to fill it. Time flies!
