New fuel pump and car won’t start?
Old Jun 26, 2023 | 07:12 PM
medianrabbit's Avatar
Soooo pretty much.I got a 3rd gen Camaro from a family friend and they drove and ran it before but it had minor fuel problems where it would just die on them .but pretty much I had the Camaro sitting for around a year and I’m finally starting to work on it .And I can’t get it to start .it starts with starting fluid spray but i can’t get it to start on its own .I’ve changed the fuel filter ,I’ve bought a new fuel pump , new fuses everywhere including the ones by the battery ,new relays .And still I can’t get the fuel pump to send fuel to the engine or injectors.I tested the power with the multimeter and there was power in the back where the pump is .but the gauge for the gas isn’t on and I hear no prime or noise coming from the pump .So I’m not sure what to do .Any help is appreciated thank youuu
Old Jun 26, 2023 | 10:26 PM
stew'86MCSS396's Avatar
Car: '86MCSS
Engine: 396 .030"
Transmission: M20
Re: New fuel pump and car won’t start?
What was the fuel pressure before and after you changed the fuel pump?
Wait a minute...are you saying the gas gauge is indicating E???
Old Jun 26, 2023 | 10:52 PM
gas gaugeis indicating way past full
Old Jun 27, 2023 | 07:45 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
You have power but do you have ground back at the pump. I've had sending units fail in this manner. Might also be the reasoning the gauge reports it's past full
Old Jun 27, 2023 | 12:52 PM
How do I check if I have ground?
Old Jun 27, 2023 | 01:48 PM
Same as you would check for power with a test light or multimeter, only difference is you hook up one end to a known good power source instead of a known good ground.
iirc, the sending unit has three wires. Power in. Ground in. Ground out for the fuel gauge. Ground out will vary depending on where the fuel level is, that's what changes the fuel gauge reading on the dash.
Old Jun 27, 2023 | 02:01 PM
Im not really sure what I’m doing
Old Jun 27, 2023 | 03:30 PM
I’m so confused .I don’t hear the pump at all even though it is connected .I tried using the ohm but I don’t know how to use it .I need help
Old Jun 29, 2023 | 05:18 PM
Update: sometype of rodent got in here because it was sitting for so long
tanager11
Oct 19, 2012 04:16 PM
Brock L.
May 18, 2012 11:42 AM
Matemk
Aug 15, 2009 09:39 PM
89camaro350tpi
Jul 25, 2009 04:33 PM
4banger82
Jan 27, 2008 01:41 AM
