OE rockers
Old 06-29-2023, 10:11 AM
BBCSwap's Avatar
Engine: SBC 400 Carb
Axle/Gears: 28 spline 323 gears
OE rockers
I have a 91 Z 350 TPI that has Crane roller rockers. Stock everything else. I am building a 400 sbc with aluminum heads. I would like to put the 350 Crane rockers on the 400 and then put some used OE rockers on the 350. I will be driving the 350 for several months before the swap. Is putting used OE rockers on the 350 a bad idea or is it ok? Will it cause the push rods to wear out prematurely? Or any other problems?
Old 06-29-2023, 10:19 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: OE rockers
Sa no guide plates elongated holes for push rods.
non sa run hardened pushrods and guide plates.
Old 06-29-2023, 10:20 AM
Engine: Lb9
Transmission: M20
Re: OE rockers
The 91 l98 should have sa rockers
Old 06-29-2023, 03:03 PM
BBCSwap's Avatar
Re: OE rockers
Ahh. Sometimes the obvious isn't so obvious. New rockers are on the way. Thank you.
Gallileo60
06-07-2011 09:34 PM
yaj15
Aftermarket Product Review
03-24-2009 11:44 AM
KamikazeIroccy
08-31-2005 05:06 AM
mustangs killer
03-30-2001 12:10 AM
Quick Reply: OE rockers
