1985 v8 5.0 305 carb IAT location?!
Old Oct 17, 2023 | 05:28 PM
Phantomwydd's Avatar
People say it’s in my air cleaner. It’s not. At AutoZone they show me a metal IAT sensor. Since it’s not in the air cleaner, where the heck is it!!!
Old Oct 18, 2023 | 08:29 AM
Re: 1985 v8 5.0 305 carb IAT location?!
Pretty sure your car doesn't have one.
Why are you trying to buy it?
Old Oct 18, 2023 | 11:04 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Old Oct 19, 2023 | 08:17 AM
I have a code for it. It says code 23. Unless the code is for the MCS, and it’s cause it failed ?
Old Oct 19, 2023 | 08:39 AM
Engine: LT1, L400
That's interesting. Is there one screwed into the intake manifold? I don't think that I've ever seen a Carb'd GM V8 with a IAT sensor.
Let me look this up. What engine VIN number is your car?
Old Oct 19, 2023 | 09:15 AM
Engine: LT1, L400
It's probably a VIN G, but doesn't matter, it's the MCS on the carb'd car.
Old Oct 19, 2023 | 09:41 AM
You said you had code 23 when you MCS was unplugged. Code 23 in a carb car means "MCS, the MCS is open or grounded, check all wiring and connections, adjust or replace MCS.". You "checked the connection", found it disconnected, and plugged the MCS back in; and told us it's now gone. Which of course was the exact right thing to do. You're now all done with code 23.
Those "codes" mean different things on different engines. After all, there's only just so many "codes" available, so lots of them they have multiple meanings, according to what system they're being applied to. Generally then, though each code may have multiple "meanings" and lead to multiple possibilities in the "troubleshooting charts", only ONE of them applies to any given engine.
In this case, since the meaning about MCS applies to your engine, the one about IAT does NOT.
You don't need an IAT because you don't have one.
Phantomwydd
Aug 29, 2023 11:08 AM
Phantomwydd
Aug 29, 2023 09:59 AM
84'Firebird
Jun 6, 2007 08:14 AM
icebird_1981
Jan 13, 2003 01:03 PM
hot86z-28
Carburetors
Jan 24, 2002 06:02 PM
