30 HP gain from stock w/only heads?
Old Jan 11, 2024 | 04:04 PM
Maker-Wright's Avatar
I've got an L98 which was harvested from a totaled 1988 Trans Am. The engine has been carb-converted (Eddy 1406 & Performer man.) Everything else remains stock, but freshly rebuilt. I'd like to keep my current gas mileage, but improve power.
Comparing specs from the L98 to the L31 5.7 Vortec, its remarkable how similar they are. Seems the only major differences are; TPI vs. TBI, and L98 heads vs. the infamous Vortec heads.
L98 vs. L31 Vortec
Dipslacement 5.7L / 5.7L
Compression 9.3 / 9.4
Comb. Chamber 64cc / 64cc
In valve 1.94 / 1.94
Ex valve 1.50 / 1.50
Cam in lift .415 / .414
Cam ex lift .430 / .428
In dur 207 / 191
Ex dur 213 / 196
LSA 117 / 111
Yet, the L98 is rated at only 225HP vs. the Vortec's 255HP. So, my question, is it probable that my L98 would get that 30HP gain by installing even better heads than the Vortec (Dart, AFR, etc.) with no other changes? I've heard NO WAY without changing the stock ex. mani's to headers, yet the Vortec manifolds look far more restrictive than the L98's...
Vortec on the left, L98 on the right. The larger "looking" area on the Vortec's are actually sheet metal heat deflectors, mounted on the outside of the casting.
2-1/8" I.D. Dual exhaust through non-restrictive Flowmasters, 700R4 with 3.73's. I love the look and fit of my stock manifolds, and gawd I don't want to mess with headers. And, I'd rather not risk losing mileage by bumping up the cam. So what do you say? Do you s'pose top-notch heads would get me 30 hp more?
Old Jan 11, 2024 | 06:47 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: 30 HP gain from stock w/only heads?
The TPI manifolds are terrible, the L31s are much better flowing by comparison. Headers even shorties are a massive improvement on a SBC. The inner passageways are larger on vortec manifolds, my L31 had 2 1/4" OD outlets and immediately stepped up to dual 3" to the muffler.
Old Jan 11, 2024 | 06:49 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
If you're concerned about fuel mileage, do not modify your engine and consider buying a modem vehicle.
That being said, yeah 20-30hp is a reasonable guess if you're moving to a nice set of heads. A larger cam doesn't necessarily mean less fuel mileage, but a little extra duration and lift could really help you hit your power goals. It really depends on how you drive it. Factory manifolds are a pretty bad choke point, I don't think I'd invest in nice heads just to plop those back on. There exists performance aftermarket cast iron manifolds if headers aren't for you.
Old Jan 11, 2024 | 08:49 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Your biggest cork currently is the manifolds, especially if those are the 2' outlet version. Swapping the heads alone will gain very little. If you cannot get the exhaust out, you cannot get the air/fuel mixture in. I just built a healthy L31 and decided to try the Hooker 2.5" manifolds on it. I know the manifolds will cost me some HP and a lot of torque compared to headers but this is a cruiser and a L03 305 TBI moved it a long well enough. The manifolds were just over $200 when I bought them. I put LT1 flat tops and the GM 94666492 camshaft with 1.6 rockers into it. Used the ProFlow4 because I got it new in the box for $1200.
Old Jan 11, 2024 | 09:58 PM
I do like the looks of those... Thanks!
Old Jan 16, 2024 | 09:45 AM
Okay... I ordered a set of Hedman 68478 mid/shortie headers, and I'm going to have to change my long straight-boot plug wires to 90-degree angle boot wires. What brand/part number of under-manifold wires do you guys suggest for an L98 with headers? I'd prefer gray or black wires.
Old Jan 16, 2024 | 09:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
https://www.summitracing.com/parts/a...+5ba0fb517989d
these work well on sbc with headers
Old Jan 18, 2024 | 09:32 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I found the 87-95 C10 wire set works well with our cars with headers. Boots are a must. Accel boots are the best ive found.
Old Jan 18, 2024 | 12:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The best I have found is the aluminum style, like a LT1 used.
Old Jan 18, 2024 | 01:58 PM
Aluminum-style plug wires?
Specifically, putting onto an engine with a distributor, the ones for an engine equipped with OptiSpark?
Enlighten us further.
Old Jan 18, 2024 | 02:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i think he means the heat shields that go around the plug boot, the little metal ones. But i didnt know lt1’s came with them
Old Jan 18, 2024 | 05:06 PM
Well maybe we'll find out. (or not?)
Old Jan 19, 2024 | 09:29 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I think he means these. GM started using them on LT and LS stuff.
Old Jan 19, 2024 | 11:58 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am talking about the 90* aluminum stamped heat shields that went on a few cylinders of the LT1. Actually I recall these in use even before that on TBIs and maybe TPIs on #5 & #7. I know the 93 Fleetwood I had used them there. The heatshields clip to the spark plug hex and the boot, preventing the wires from flopping around as well.
Old Jan 19, 2024 | 12:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Taylor had them for the longest as part number 2570, although they are currently not showing in stock at places. Rock Auto had them for $3-4 ea in the Standard Ignition line. I bought a few sets of 8 from Oreilly as well for about the same. Before that I bought them from GM. I say they are alumimum because I dropped one under the motor mount on my Express and it would not stick to a magnet. Ended up having to pull out the remote operated retrieval claw to get it out.
Old Jan 19, 2024 | 01:59 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Interesting i havent seen those but the round complete shrouded ones posted above by shifty
Howster27
Feb 23, 2017 05:03 PM
91greenbird
Jul 22, 2007 09:50 PM
tpirocz
Sep 11, 2002 12:29 PM
Brian'sIROC
Jul 19, 2002 11:13 AM
BillZ28
May 16, 2002 10:26 PM
