Gas in Oil
Gas in Oil
So for the past 6 years my wife has mentioned it to several different dealerships that her oil smells like gas each time she gets an oil change. They always tell her that’s not gas it’s oil smell.
She drives a 2017 Chevy Equinox.
Well fast forward 7 days after her last oil change she was having oil level issues. That turned out to be a spray all under the hood but there was no puddle underneath and dip stick was bone dry! We had it towed to the dealership. I suspected it was an internal engine leak! They said there is NO oil leak but the PVC valve needs replaced. Also a 3 part Complete Fuel Service. $3259
My question is if this has been going on truly for 6 years what kind of damage could’ve been done? She keeps yelling at me because she is suspicious that they know there is more wrong and it’s a $$$ grab because this is the actual dealership we bought her SUV from! Plus she’s had 18 oil changes there!
Thanks for your input! Have a great day/night! Be safe! Stay warm!
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
Re: Gas in Oil
Do you have the 2.4 or the 3.6?
The earlier 2.4 was known for excessive oil consumption, usually ended up needing pistons and rings. There's no special coverage on 2017 that I'm aware of, but it doesn't mean it isn't susceptible to the same issues
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Gas in Oil
The Equinox is a terrible vehicle. Do yourself a favor and have it crushed for scrap, and buy a third gen.
Also, do your own oil changes.
Re: Gas in Oil
This is a forum for 82-92 Camaro & Firebird, not a general tech Q&A site.
Sounds like you need to quit taking your car to a stealership and instead learn how to fix minor stuff like this on your own.
Musta got a bad injector from the factory. Fornicated since Day One.
If the oil smells like gas it's because there's gas in it. Not too hard to figure that out. For an older vehicle like ... 82-92 Camaro & Firebird ... with a mechanical block-mounted fuel pump, that pump would be the most likely cause. More likely however, since your car does NOT have that style of fuel system, your problem is a bad fuel injector. Chech with the sponsors of this board that sell fuel injectors; I think, for about a tenth of the money you've wasted at stealerships, and maybe a half-hour of your time, you can take care of it. Somebody on an Equinox (or related) forum could probably fill in the details WWWWWWWWAAAAAAAAAAAYYYYYYYY better than I ever could, though.
This is why I do ALL the work on my own fleet, to the greatest extent of my capabilities.
Probably not much, if she's kept it full of oil.
Maybe while you're at the girl stealership next time you can trade her in on a newer model that won't yell at you so much over stuff that's not your fault to begin with.
it's a $$$ grab
Re: Gas in Oil
Dealership says: she needs Intake Manifold/PCV Gasket, Complete 3 part Fuel System, Oil Change! $1500
Re: Gas in Oil
I don’t have time to change her oil or do repair as I’m an Over the Road Truck Driver. I stay out 45 days at a time and come home for 2 but those 2 days off I’m consumed doing other things from the “Honey Do List”
Yes she stays on top of oil and the changes!
Shhh you know they say we truck drivers have girlfriends in every state. I’m NOT that bad but I do have 2 ones a female driver the other is another state!
I truly appreciate you advice and input!
Re: Gas in Oil
