Tilt wont lock + igintion dead on steering column
Old Mar 31, 2024 | 12:47 PM
1991Patricktroy's Avatar
Car: 1991 Z28
Went to fire up the 91 Z28, and three issues:
- Tilt steering wont lock (rocks up and down)
-does not seem to lock wheel for "left/right" steering
-key is like turning in mud (No spring) and does not power up anything (not even aux)
I have owned this 91 Z28 since new and stock steering column. All three issues happened t same time.
Any suggestions or replacing parts/links?
Thank you for any help!
Old Apr 1, 2024 | 08:37 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: Tilt wont lock + igintion dead on steering column
Is the whole tilt mechanism loose? Meaning does the wheel and housing (where the key and turn signal stalk are) move around up/down and left/right?
That's really common. If it's doing that, its loose bolts in the tilt mechanism that need to be tightened. A few special tools, but not hard to do. When it loosens up like that, the ignition lock linkage can also jamb up.
Old Apr 1, 2024 | 09:31 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
X2
Also, there are three bolts that hold the tilting part of the column to the tilt mechanism, I've had columns where those loosen up and cause the same symptoms. Either way, you need to tear the column apart to fix it.
Kevin84Z28
Jan 7, 2005 10:43 PM
camaro_junkie
Apr 23, 2003 06:24 PM
84fire
Feb 22, 2003 06:32 PM
