Oil cooler removal
Old Apr 6, 2024 | 08:43 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Oil cooler removal
I'm doing an a/c rebuild on my GTA and I figured while the radiator is out I might as well replace it with a new one. Decided to also replace my coolant hoses, and noticed that my metal oil cooler lines are pretty badly rusted on the inside. I just hate the thought of that rust making its way into my new radiator, so I'm considering just removing the oil cooler all together. I'd like to keep my car stock, but that thing just seems like more trouble than it's worth, and I use synthetic oil anyways.
How difficult is it to remove? I'm assuming it's just a couple of bolts? I looked on YouTube and didn't really find any videos.
I suppose another option might be to just cut out the metal lines and replace with rubber heater hose, but I'm not sure how well that would work. Seems like they'd just be flopping around under there without any way to secure them.
Old Apr 6, 2024 | 09:06 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: Oil cooler removal
You'll need a new oil filter adapter, that's it. Not very difficult. Definitely do not do the heater hose thing.
Old Apr 6, 2024 | 09:10 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Is this it?
https://www.autozone.com/filters-and...B&gclsrc=aw.ds
Old Apr 7, 2024 | 12:17 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Yep, you will also need to buy two 5/16"-18 x 1 1/4" bolts to install it. Blue loctite recommended on those. The gasket is controversial.
Old Apr 7, 2024 | 10:00 AM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
thanks. I ordered one from Amazon so it should be here tomorrow. $10 cheaper than the parts stores.
Im a bit confused on the filter. Will the normal size filter for a 350 work? I see some reviews saying to buy the filter for a 454, but then some of those are for 4wd and talk about not clearing the front drive shaft.
Old Apr 7, 2024 | 10:06 AM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Whatever size WIX #51060 is fits in a third gen. Unless you've got a front driveshaft.
Old Apr 7, 2024 | 11:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
You don't need a different oil filter adapter, just swap out the 2 bolts that locate cooler.
Old Apr 8, 2024 | 02:52 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Hawks sells reproduction oil cooler hard lines made of aluminum if you are interested in keeping the oil cooler. Otherwise, you can certainly eliminate it and remove the lines and heat exchanger. As was already stated, the oil filter adapter is the same, just uses different bolts. Same oil filter with or without the cooler.
Old Apr 8, 2024 | 06:56 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
I did see those and I may consider them down the road. I'm going to clean the cooler and save it just in case.
Those new lines look like they would be tough to install though, without raising the engine.
Old Apr 9, 2024 | 05:53 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Your post confused me until I removed the cooler and discovered the adapter is already in there. Not sure why my car already had one when others say they needed one?
Anyways, the GM one looked way better built then the pot metal Melling one, so I reused it.
Old Apr 9, 2024 | 06:19 PM
Car: '89 GTA
Engine: ZZ6TPI
The same adapter is used for either the oil cooler or no oil cooler and just the oil filter. The only difference is the bolts. No oil cooler uses standard hex hex head bolts and with the oil cooler uses hex bolts with extension pins to keep the oil cooler from rotating.
Yes, the GM adapter is better made.
Old Apr 9, 2024 | 06:22 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
why do some posters here say they needed to buy the adapter? Just curious.
Old Apr 9, 2024 | 06:31 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
Needed it to convert the L31 I had with the cooler, I guess it depends on what motor you're using.
Old Apr 9, 2024 | 07:21 PM
TTOP350's Avatar
Depends on type of cooler used.
Old Apr 9, 2024 | 07:46 PM
Car: '89 GTA
Engine: ZZ6TPI
Not sure. There are other types of oil coolers that use a different adapter, but they didn’t come on thirdgens.
Old Apr 9, 2024 | 08:20 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
In one of them the oil leaves the engine, flows through the oil lines into the oil cooler inside the radiator endcap and back into the engine.
In the other one coolant leaves the cooling system, flows through the coolant lines into the engine oil warmer on the engine then back into the cooling system.
Two different styles of oil cooler/warmer depending on how you want to look at it. I prefer the one that doesn't dump all your oil out if it fails. Or better yet neither of them and run a high quality synthetic oil. I prefer the oil stays in the oil system and the coolant stays in the cooling system.
Synapsis
Aug 24, 2020 10:04 PM
specvgini
Oct 21, 2005 08:52 PM
9225th
Jun 24, 2002 01:55 PM
86IROCZ
Apr 10, 2002 11:32 PM
