Heavy Vibration Shaking and rough start
Old May 3, 2024 | 06:14 PM
okamihybrid's Avatar
Car: 1989 Firebird Formula
Engine: 350 SBC
Transmission: T5, wanting T56 swap
Recently picked up an 89 firebird formula as my first project and manual car as the third gen birds are my dream car(mmhm popups), however I have encounted some nice and very fun issues. The primary one which was my main concern is just how aggressively the car shakes and vibrates at any speed, especially at idle and with the shifter. It also has a bit of a rough start at times, however I believe the no crank is an ignition /wiring issue since the cylinder is a little loose and if i hold it and adjust the wheel it will crank and start. I have replaced all but two sparkplugs, which I am about to go and buy a sparkplug tool to cut in half so it'll fit behind 5 and 8 and checked the wires and they seem to be in the correct firing order and connected to the right cylinders. I imagine the vibration is the motor mounts or trans mounts, however visually I couldn't see anything with the motor mounts. The oil is full, but is lookin a little black so I will be changing it soon. Any assistance is appreciated, thank you
File Type: mov
File Type: mov
DeltaElite121
Feb 7, 2013 05:38 PM
TNT_Z28
Apr 26, 2011 10:45 AM
transambill
Jun 22, 2003 02:13 AM
88 WS6 TransAm GTA
Mar 12, 2003 09:48 PM
86camarodriver
Jan 21, 2002 05:35 PM
