93 octane or 90 octane non ethanol
Old Jul 18, 2024 | 11:41 AM
hyperman85's Avatar
I have an 85 z28 with carb. Should I be running 90 octane non-ethanol in it?
Old Jul 18, 2024 | 12:21 PM
czarjl's Avatar
Car: '82 Camaro Berlinetta
Engine: 305 Carb
Transmission: TH200
Re: 93 octane or 90 octane non ethanol
Is your motor stock, is it modified (how so), are you getting knocking?
Most healthy stock motors are fine with 87 octane... 93 octane will give you nothing unless you need a more detonation resistant fuel.
Now running non-ethanol fuel may have some benefits but it has more to do with the lack of ethanol than the octane rating.
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
93 with ethanol will be more resistant to detonation. 90 without will burn more efficiently. On a factory 85 z28 probably wont make any difference
Old Jul 18, 2024 | 12:32 PM
hyperman85's Avatar
Completely stock. I am thinking that 90 octane ethanol free is best for it?
Old Jul 18, 2024 | 01:01 PM
midias's Avatar
Completely stock 87 would probably be best.
Old Jul 18, 2024 | 01:08 PM
If it's the LG4 (VIN code H) then 87 would be best.
Old Jul 18, 2024 | 02:54 PM
hyperman85's Avatar
To clear up my title. The 93 octane has ethanol and the 90 octane does not
Old Jul 18, 2024 | 03:11 PM
midias's Avatar
still 87
Old Jul 18, 2024 | 03:19 PM
Doesn't matter. You don't need the octane rating if it's the LG4. It'll run the same and use less if you put in 87, and it'll cost less per unit, besides.
Now, if it's NOT the LG4, then the discussion might need to be revisited.
pgh1992
Feb 28, 2009 02:52 PM
camshaftxe
May 6, 2008 11:22 PM
GoodlookinRS
Mar 30, 2008 06:35 PM
westman
Nov 27, 2003 10:21 AM
demonkey36
Aug 12, 2002 09:59 AM
