1987 GTA AXLE QUESTION
I have a stupid question guys, I have a 1987 GTA it is a disc brake posi traction car. I have an axle seal leak on my passenger side. My question is which bearing and seals do I have. Im so confused. Im on rock auto trying to figure out what I need. I got options for 7.75 or 7.625 how do I know. Not an axle expert by any means LOL. Thanks in advance guys
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Car: '89 GTA
Engine: ZZ6TPI
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
Re: 1987 GTA AXLE QUESTION
Uh, I'd go with Tom 400's answer. Go under the car and count the bolts on the diff cover. Everything else is a guess after almost 40 years...
Another thing to bear in mind if the axle is a Borg unit - The axle shaft seals may be different for the two sides.
The seal is outboard of the bearing, and the bearing R&R will require a substantial press to do the work. Obviously, there is no re-using the bearing/retainer collar once it is pressed off.
Engine: 4++,350 & 305 CIs
The 9bolt has a rubber plug on the diff cover.
PerfectionGoku
Aug 9, 2002 11:36 AM
