Key replacement
Old Jan 11, 2025 | 01:45 PM
Tony Scotland's Avatar
Car: 1989 Camero Iroc Z convertible
Transmission: Auti
Key replacement
Hi, I’ve purchased a 1989 convertible. The keys got lost between the previous owner and myself. Is it possible to get a key made just by providing details of the car such as VIN, body etc? Or is there a stamped number in the car somewhere which would help? I don’t want to go down the road of replacing the ignition key as this affects the locks and trunk. Cheers
Old Jan 11, 2025 | 01:51 PM
pirateofms's Avatar
Car: 1989 Firebird
Engine: 2.8 V6
Re: Key replacement
Replacing the ignition key doesn't affect the doors and trunk, they're separate keys. You'll need to find out what vats value you need and order a matching blank, and then either take the ignition lock cylinder out and to a locksmith to have a key made, or just buy a new one with key, and have that key copied to your VATS chipped key.
Old Jan 11, 2025 | 01:54 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Key replacement
Not sure if this helps you or not, but.......
The ignition key has absolutely nothing to do with the "locks and trunk" (presuming your talking about the door locks and trunk?)
The square key with the resistor "pellet" in it operates the ignition only, the round key operates the door locks, trunk lock, trunk storage compartment.
Ri-Key - New B62 P4 Chevrolet Camero ...
Old Jan 11, 2025 | 02:05 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Key replacement
And this brings up another pain in the azzz your gonna need to deal with, since you say your car is a 1989;
Are you aware of "VATS" ?
If not, your gonna have to be. Since you don't have the ignition key, your gonna have to deal with VATS (Vehicle Anti Theft System). That little resistor pellet in the key had 10 different possible resistances, and if the VATS module doesn't see the right resistance, the engine isn't going to start. VATS inhibits two things if it doesn't "see" the right key resistance, the starter's ability to crank the engine and the ECM's ability to pulse (operate) the fuel injectors. There are several ways to deal with VATS, you will be best served by searching VATS here and reading and learning about what your up against here.
Old Jan 11, 2025 | 02:06 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Key replacement
And...... Pirate best me to the post by mere minutes...
chat6
Jul 29, 2023 10:36 PM
yogi492
Apr 7, 2022 01:09 PM
Fbodyman7389
Feb 3, 2019 12:15 AM
whazup
Apr 4, 2005 06:42 PM
