?'s about transponder keys
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
If you are refering to the vats system with the pellet in the key, you will need to know what resistance the original had..(o-999) ohms. A dealership will be able to cut a key off your vin, but they still may need to know what resistor so the pass key module will accept the key.
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
You dont program the key. There is no circuit on the key even. It's just a resistor. You can check the resistance of your current key with an ohm meter and do what you want with that but you're much better off just going to a dealer to get a new one cut.
Car: 1992 Z28
Engine: 355
I went through this last fall. I lost my keys the day before our wedding
First of all, a normal GM key will not fit in a VATS key cylinder. GM can cut you a new key using your VIN but you now have to pay for them to go into the database. The ****ty part is that the VIN search will only give you the proper pattern to be cut into the key. It won't tell you what value the "chip" has. And the "chip" is actually a diode.
The VATS keys are also around $60
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It is a resistor. I've bypassed enough of them with 20 cent resistors to know.
http://www.asttraining.com/Files/vats1.pdf#search=
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Engine: SBC, LS-x
Originally posted by Acceld Z
GM calls it a diode. I think it's another term for resister.
But you can go ahead and get your drawers in a bunch if you'd like
Folks are still calling them chips. I've had people try to tell me it's a tiny computer or IC.
The truth is it isn't. It's a simple resistor.
Engine: SBC, LS-x
Originally posted by Daz
thats good a good illustration..Might be against thirdgen.org policy though
Car: 1992 Z28
Engine: 355
A misinformed guy at the parts counter might call it a diode. A diode has a totally different purpose in electronics.
SO
the deal i was told was full bs , theres no was than the car will self-program to except a new key !!!
i was told if i had right key cut all i had to do was
- insert key , turn to on position for 10 mins
- turn key to off position for 1 min
- repeat 3 times
i was told by doing this it programs the computer to that key
btw ... the car is a 1989 Trans-Am , lost the key
- repeat 3 times
"the deal i was told was full bs , theres no was than the car will self-program to except a new key !!!
- repeat 3 times
btw ... the car is a 1989 Trans-Am , lost the key "
That`s the procedure to learn the pass lock sysytem, don`t confuse that with your pass key system. The pass lock and pass lock II systems have a transponder in the ignition tumbler that sends a signal to the dash head and the head sends another signal the PCM..as long as it all matches it will alow spark and fuel..you don`t have this though. Were stuck with the tumbler that breaks..but hey at least when we change the computer, dash head or crank sensor we don`t have to relearn the security system.
- repeat 3 times
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
