Cam suggestions
Old Mar 8, 2025 | 10:38 AM
Chaddyboy's Avatar
Cam suggestions
Looking to see my cam options on my 87 camaro iroc 350 it's been converted to carb. I would say it's stock in all aspects but would like to put a mild cam in it. Any suggestions would be appreciated.
Old Mar 8, 2025 | 02:19 PM
Re: Cam suggestions
Look at one about like this.
You WILL need valve springs: don't EVEN hallucinate that you can "get by" with stock ones. About the cheeeepest way to go would be these springs & retainers. Set them up at 1.800" installed height, with no oil splash shields or rotators of course. Use the FelPro "positive" seals on both intake and exhaust; don't bother with "umbrella" type or the O-rings.
Cam https://www.summitracing.com/parts/sum-8802
Springs https://www.texas-speed.com/p-9573-g...laced-ls6.aspx
Retainers https://www.summitracing.com/parts/cca-787-16
Keepers https://www.summitracing.com/parts/hrs-93005
Seals https://www.summitracing.com/parts/fel-ss72527
Shim Set https://www.summitracing.com/parts/cca-4753
Spring Height Mic https://www.summitracing.com/parts/btc-btrhm
Old Mar 8, 2025 | 02:49 PM
Chaddyboy's Avatar
Re: Cam suggestions
wow hey thanks I appreciate all your input however I'm being told that cam is to big and I would need more lift .
Old Mar 13, 2025 | 03:15 PM
Chaddyboy's Avatar
Re: Cam suggestions
anyone else also wanna chime in
Old Mar 13, 2025 | 04:16 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Re: Cam suggestions
Looking to see my cam options on my 87 Camaro IROC-Z 350 it's been converted to carb. I would say it's stock in all aspects but would like to put a mild cam in it. Any suggestions would be appreciated.
Are you saying the L98 engine is stock in all aspects other than the TPI and distributor being swapped or the entire car is stock in all aspects including the engine?
Is the exhaust system stock? If not give some details of what you have on it now.
Old Mar 13, 2025 | 04:34 PM
Re: Cam suggestions
Whoever told you that, needs not to be listened to. Not least because, it's internally inconsistent with itself; "big" = "more lift". Butt also because, if you still have the stock heads, the valves can open only just so far, before the retainers crash into the top of the guides; which is the absolute hard upper limit to how much "more lift" you can have. Something around .525" is the end of the line which is why I suggested that one. However if you want one a bit smaller you could go with this https://www.summitracing.com/parts/sum-8801 or https://www.summitracing.com/parts/sum-8800.
Old Mar 13, 2025 | 05:03 PM
Chaddyboy's Avatar
Re: Cam suggestions
yes the 350 is now converted to carb and yes i have eldebrock long tube headers with flowmaster cat back system
Old Mar 13, 2025 | 05:04 PM
Airwolfe's Avatar
Re: Cam suggestions
I like the 8802 cam you suggested for him for a stock L98 converted to carb. Agree about the rotators, splash shields, and valve stem seals. Don't know about the other stuff because I didn't look at it. You know what you are talking about there so I didn't bother with thinking about it.
I was going to suggest a 2200 to 2500 RPM HD lock-up stall convertor and some exhaust upgrades to go with it. At the very least get rid of the horrible factory T merge pipe before the cat and go with the nice Magnaflow 16450 Y merge piece for single cat H.O. exhaust systems.
I was going to suggest this 4L60E 700R4 2200-2500 STALL CHEVY TORQUE CONVERTER 30 SPLINE LOCK UP HEAVY DUTY | eBay to go with your upgrade. Your 1987 L98 IROC-Z came with a BW 9 Bolt with 3:27 gears and I think the 8802 cam and your exhaust upgrades will fit nice with it.
Old Mar 13, 2025 | 05:32 PM
Re: Cam suggestions
There's no such thing AFAIK. Edelbrock (yes, I'm gonna take that leap of faith) doesn't make "long tube headers" and never has AFAIK. They did at one time offer their "TES" (Tubular Exhaust System) butt it wasn't "long tubes". It had very short tubes, with the flanges that went to its crossover pipe, very close to the stock location.
Nonetheless, it was a SIGNIFICANT improvement over the stock manifolds and Y-pipe, although it left ALOT to be desired in terms of overall optimization. Their Y-pipe in particular was kinda crudely made and left alot to be desired. Dyno Don used to supply a replacement for that for certain models, not sure if he still does.
I STRONGLY agree with Airwolfe's converter suggestion. Depending on what gears you have now, which since they're most likely 3.27 if they haven't been changed which makes it easier since they're 3 series, upgrading those might also be a true game-changer. Anything that lets the engine get up out of the idle RPM range will help it produce more USEABLE and FEELABLE (is that a word?) power.
Old Mar 13, 2025 | 06:27 PM
Airwolfe's Avatar
Re: Cam suggestions
Top-Down Solutions - Dyno Don's Single-cat Y-pipe for Edelbrock TES Headers
The Eddy Y-pipe design was crud where the two pipes combined.
The metal was very poor quality and usually rusted and pitted quickly.
Don's look much much better than the original design IMO.
High resolution picture. Click on it and zoom in on the horrible crimped in Y merge.
The stock Edelbrock Y-pipe for their TES headers was absolute hot garbage. The 2 into 1 Y merge was horrible. Dyno Don's is an order of magnitude better.
Below is @Dyno Don much improved Y-pipe design for the Edelbrock TES headers. I believe there are more than one design for the Edelbrock headers that fit 3rd gens. Need to verify with Don which set you have and if they will fit his replacement Y-pipe.
Old Mar 13, 2025 | 06:44 PM
Re: Cam suggestions
Don is getting up there in years and trying to retire. Can't say I blame him for that. He's backing off of all that stuff he used to do. https://www.thirdgen.org/forums/exha...n-headers.html for example. If he still makes those, great; but just because Lon still has a page for them on his web site, is no guarantee that Don is still making them. Might be worth asking though.
Old Mar 13, 2025 | 07:06 PM
Airwolfe's Avatar
Re: Cam suggestions
Don has a fresh batch going again. They just loaded all his headers, Y pipes, and a bunch of other stuff. New stuff too I never seen him offer before.
Top-Down Solutions - Powertrain Performance
Wouldn't hurt to call and ask though to be sure.
@Dyno Don @lonsal
Old Mar 13, 2025 | 07:36 PM
Re: Cam suggestions
Yup. Check w Don himself. Not sure that just because something is on Lon's (top down) site, that Don is actually making it. Not that Lon is lying or anything, just, go to the source. You might well find for example that there's a minimum order quantity before he'll even start anything, or some such. Another way to reach him might be, Kevin 91Z that used to be on this site alot, lives out in OC and knows Don, and is able to talk to him directly sometimes. Might be worth PMing him.
Old Mar 13, 2025 | 09:55 PM
Airwolfe's Avatar
Re: Cam suggestions
December 12th 2024
Originally Posted by Dyno Don
The headers are ready for orders..... go to:
top-downsolutions.com
https://www.top-downsolutions.com/po...in-performance
December 13th 2024
Originally Posted by lonsal
Yes I am taking orders for Dyno Don headers again. on my website.
Lon Salgren
Top-Down Solutions
626-369-0040
Old Mar 14, 2025 | 04:06 AM
Chaddyboy's Avatar
Re: Cam suggestions
Regarding the headers maybe i was wrong but it does say elderbrock on them but has the pollution tube deleted.
Old Mar 14, 2025 | 07:14 AM
Re: Cam suggestions
There's no one I'm aware of (not that I'm aware of EVERYTHING) called that name you are using in the header industry.
As said, Edelbrock www.edelbrock.com DID in fact make header systems at one time, which they called "TES" (Tubular Exhaust System), but no longer appears to; at least, there's no hint of them on their web site anymore. However they were NOT "long tubes". They were shorties, and included their own Y-pipe, all of which was designed to fit where the stock manifolds and Y-pipe are. They came in many varieties to be compatible with the stock components around them; for example the ones for carbed cars like mine had provision for the EFE valve at the pass side header exit into the Y-pipe, and they had the correct flange or other connection at the Y-pipe output to hook up to the various stock catalytic converters in our cars, which in my case, meant the 4-bolt flange. Most of them had the AIR tubes because they carried a CARB EO exemption; I don't recall if all of them did. No doubt lots of people in the other 49 states cut those off. I still have a set laying around, myself, that I bought in the early 90s sometime, which since I moved to California for awhile in about 2000 and lived there for some time, came in handy when car licensing time came around. I'm not saying you don't have Edelbrock headers; I'm merely pointing out what the correct name is, and that they are NOT long tubes.
Old Mar 14, 2025 | 01:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Cam suggestions
Kevin is Don's son.
Old Mar 14, 2025 | 01:33 PM
Airwolfe's Avatar
Re: Cam suggestions
Old Mar 14, 2025 | 03:01 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Cam suggestions
This topic bas certainly strayed from the title "Cam suggestions". Regardless, Yes Dyno Don still makes the y-pipe for the Edelbrock TES headers. We've had a few customers with Edelbrock headers and rusted out y-pipe, so years ago Don stepped up to supply a solution. This is why it's still on my website. All that being said I haven't yet taken any orders for these since production methods have changed, so there is a possibility they can no longer be made. I'll place any order I receive with Don and we'll find out the current status. Sorry, I can't help you with a cam recommendation.
Lon Salgren
Top-Down Solutions
626-369-0040
Old Mar 14, 2025 | 03:03 PM
Re: Cam suggestions
Fast:
Yes I know that. Now everybody does. I was avoiding going there. I respect their privacy.
Old Mar 14, 2025 | 03:48 PM
Chaddyboy's Avatar
Re: Cam suggestions
Lon Salgren
Top-Down Solutions
626-369-0040
how about the infamous Don headers any available
Old Mar 14, 2025 | 04:00 PM
Re: Cam suggestions
Once again, I spoon-feed.
Old Dec 19, 2025 | 08:17 AM
Chaddyboy's Avatar
Re: Cam suggestions
well it's been a while but I just got around to ordering all the parts..I have a few more questions as I'm getting different opionions...First do I have to cut the valve seats regarding the cam also do I need to use roller rockers or can I used my factory stamped ones..Cheers.
Old Dec 19, 2025 | 08:55 AM
Re: Cam suggestions
cut the valve seats
Not sure what this means. Please clarify what you're asking about.
​​​​​​​do I need to use roller rockers or can I used my factory stamped ones
You can use the factory stamped-rubber CRAP if you want. Be aware though, roller-trunnion rockers will lower your oil temp by 5 - 10°F due to losing the ball flucrum thing which gets hot enough to turn the metal blue; and of course, the ACTUAL ratio of stock rockers, claimed to be 1.5, actually MEASURES anywhere from about 1.38 to 1.45 with most ACTUALLY MEASURING in the 1.43 neighborhood. And of course the sliding action of the tip of the stock rocker puts side force on the valves in the guides, which increases as the rocker's motion becomes a longer arc (i.e. higher lift). Even just switching to more rigid ball-fulcrum rockers with roller tips such as the Comp 1400 series is a MASSIVE improvement over the stock rubber ones in spite of retaining the ball fulcrum design. Avoid the chinesium knockoffs of those that you see everywhere, the pennies you might "save" aren't worth it in the long run.
Old Dec 19, 2025 | 10:20 AM
Chaddyboy's Avatar
Re: Cam suggestions
sorry I meant valve guides.
Old Dec 19, 2025 | 11:08 AM
Re: Cam suggestions
Oh that...
Not necessary. Which is why I posted those particular ones. They are an eeeeezzzzzy upgrade that doesn't require machine work.
Old Dec 19, 2025 | 11:51 AM
Chaddyboy's Avatar
Re: Cam suggestions
comp series 1400 you mean there magnum series?
Old Dec 20, 2025 | 07:10 AM
Chaddyboy's Avatar
Re: Cam suggestions
[QUOTE=sofakingdom;6576915]Oh that...
Old Dec 20, 2025 | 08:06 AM
Chaddyboy's Avatar
Re: Cam suggestions
[QUOTE=Chaddyboy;6576941]
Oh that...
gotcha...final question are my sock pushrods ok to use with my set up...there in fantastic shape.
Old Jan 8, 2026 | 04:29 PM
Chaddyboy's Avatar
Re: Cam suggestions
crappppl just bought all those parts to find out the last owner ripped out the 350 and put a 305 in ...ugggh does this change things much regarding power.
Old Jan 9, 2026 | 06:24 AM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Cam suggestions
Yes, a 350 will make more power than a 305, all else being equal...
Old Jan 9, 2026 | 07:56 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: Cam suggestions
^That.
BUT...a 305 w/a little cam added, is still better than a 305 w/a stock cam.
65panhed
Feb 27, 2024 09:40 PM
89406Iroc
Apr 24, 2004 09:32 AM
OMINOUS_87
South West Region
44
Feb 1, 2004 12:58 AM
incus86
Nov 2, 2003 08:39 PM
