Gauges fuse keeps blowing
Old Mar 11, 2025 | 10:57 PM
severe97's Avatar
I recently had to take the steering wheel off to work on the key cylinder. I fixed that and put it back together and now the gauge’s fuse keeps blowing. I’ve gone through two 10 amp fuses. I went back and took the steering wheel off again to inspect the wiring and couldn’t find anything. One thing worth mentioning is the two copper connections by the key ignition cylinder were bent but corrected during the install. I have no idea how to troubleshoot.
Any suggestions?
Old Mar 12, 2025 | 09:17 PM
Vader's Avatar
Re: Gauges fuse keeps blowing
What year/model?
In some years, the GAGE power served the key warning buzzer (in the under-dash convenience center) and the cruise control module. Both of those have wiring into the steering column. The key warning buzzer used light green and tan wires to/from the column, and the cruise control used a blue wire to the switch on the turn signal lever.
Old Mar 12, 2025 | 11:59 PM
severe97's Avatar
Originally Posted by Vader
What year/model?
92 Z28
Thanks. I did have to take the buzzer off because it kept ringing while the key was on the cylinder. Thanks for your input. How do I fix it? What do I do with the light green and tan wires?
Old Mar 13, 2025 | 07:23 AM
Vader's Avatar
Meter/trace/inspect the suspect wires for shorts, pinches or cuts to grounds, etc.
There are also VATS and SIR wiring on a '92 but those should not affect the GAGES fuse.
Old Mar 16, 2025 | 04:08 PM
severe97's Avatar
quick question, is the buzzer supposed to buzz when the key is on? Just Key in the cylinder off position?
Old Mar 16, 2025 | 04:13 PM
severe97's Avatar
I think I found the problem, tan wire is damaged, you’re a genius!!
Old Mar 16, 2025 | 09:00 PM
Vader's Avatar
Good that you located it.
Genius? Ure lukky eye can speel wiyer...
Pickle83
Nov 17, 2014 07:38 PM
a1990camaro
Dec 23, 2008 11:06 PM
Mad Morgan
Jul 31, 2004 07:42 PM
WickedZ28
Apr 16, 2002 01:18 AM
camaro 22
Apr 24, 2001 02:50 PM
