What size fitting?
Old Apr 23, 2025 | 09:37 PM
84StarshipBerly's Avatar
Car: 1984 Camaro Berlinetta
Engine: 350 sbc .60 over
Transmission: 700r4 2800-3000 Stall
Axle/Gears: 7.5" 28 spline axles. 3.42 gears
What size fitting?
What is the size of the fitting that goes into the steering rack for the power steering? Thanks!
Old Apr 24, 2025 | 07:42 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: What size fitting?
16mm x 1.5 and 18mm x 1.5
Old Apr 24, 2025 | 08:51 AM
Note also that the type of fitting is the Saginaw O-ring type. Looks something like the O-ring end of this except that the OEM part had a nut that was free to turn on steel tubing rather than a single solid object. https://www.summitracing.com/parts/dsr-090202sds There's 2 possible sizes, this one and the other one. Please excuse the cryptic description the mfr uses for its application. There are also other mfrs and suppliers of course.
Old Apr 24, 2025 | 03:27 PM
Alright. I’m trying to convert it to an hose but I’d see two different sizes for the steering box apparently. I was thinking at first it was 11/16 -18 inverted but then there’s also the metric like what shiftycapone mentioned.
Old Apr 24, 2025 | 04:27 PM
It's metric. Blee Dat.
Did you click on the link I gave you? Does the description match your car? Then it's one of the 2 potential right ones. What was its size? Use your calipers to see if it's that one or the other.
It's just not that hard. Don't make it so.
Old Apr 24, 2025 | 07:06 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Many fitting manufacturers make make AN to metric adapters.
Old Apr 25, 2025 | 01:50 AM
Yeah I went to the link it helped and figured out which one it was I needed and found the adapter to go AN line. Already ordered it and it’s the last piece to get my car back on the road. Appreciate the help!
Old Apr 25, 2025 | 07:39 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Make sure whatever AN line you use is pressure rated for power steering. Most PTFE hose can accommodate those pressures.
PS. Didn't mean to click edit on your post. Nothing was changed, just me not paying attention.
Old Apr 25, 2025 | 11:24 AM
Yeah I already have an AN power steering line rated for it and the fitting in the pump all I needed was the one for the steering box.
Old Apr 25, 2025 | 12:39 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Which brand did you end up going with? I am using Aeroflow, which is awesome, but coming from Australia is impossible to get parts in a timely manor.
Old Apr 28, 2025 | 03:05 AM
I’ve been using evil energy fittings off Amazon. I just swapped a motor into my third gen that I’ve been building and all the fittings I used for the fuel lines has been evil energy. I wasn’t too sure about them at first but they have so many different sizes from like -6an to 3/8 npt and even more and swivel 90 degree an fittings and even push lock which is what I used for the fuel pump that then converted to an. Doesn’t cost an arm and a leg like most other brands and with thread sealer I didn’t have a single leak on first start and 2500 rpm break in. Also used them for the power steering now but need a new belt so not sure how they seal but I’m going to assume fine.
Old Apr 28, 2025 | 10:00 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I've used their fittings and adapters too but never their PTFE line. I'll have to check it out sometime.
Old Apr 28, 2025 | 02:36 PM
The push lock isn’t ptfe it’s just 3/8 rubber fuel line basically but it’s from evil energy. I haven’t tried any of their actual ptfe line yet. The only ptfe line I have is the power steering I got pre made from ict billet.
Old Apr 28, 2025 | 07:46 PM
Vader's Avatar
I think it's a trick question. There IS no steering rack on a ThirdGen.
Old Apr 28, 2025 | 07:47 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Not with that attitude........
Paul Riccioli Jr
Oct 29, 2015 11:31 PM
SmoothCustomer
Jul 30, 2014 11:51 AM
PATRIOTIC1911
Apr 4, 2014 11:49 AM
SatisTraction
Dec 15, 2007 07:25 PM
