High oil pressure
High oil pressure
Hi guys.I have a 1988 Iroc-z 350 that has high oil pressure.I have replaced the gasket that goes between the block and where the oil cooler presses up against it and it blew out for the second time.The oil guage is pegged at the high end of the scale when the gasket blew out.Anybody else have this issue? Thanks.
Re: High oil pressure
Sounds like the bypass valve in the oil pump is stuck. (closed) No way for it to regulate the pressure that way, it just goes for broke. Usually due to debris or damage to the valve's bore.
A little history would help. Guessing at this sort of thing in an information vacuum is just abuncha ... guessing.
Car is all stock with 230k on it.On Wednesday the aforementioned gasket blew out and I had 4 quarts of oil all over the drive way.Got under the car and noticed the gasket was bulged out.Removed oil filter and oil cooler took out old gasket and replaced it with anew one.Started the car and the pressure was through the roof.Drove it to work about 3k away and it blew out the same place as before.Now my work has 4 quarts of oil all over the parking lot.Could this have something to do with the oil cooler being blocked or the oil bypass in the oil filter adaptor being blocked?
Car: 1989 Pontiac Firebird Formula 350
Engine: 5.7 TPI
Axle/Gears: 9 Bolt 3:27
Engine: 4++,350 & 305 CIs
Possible Sending unit failure? along with a cracked or broken oil filter adapter. Have had that happen before.
Stock oil pressure guage.It was fluctuating for a while then it pegged out high then it blew out.Sofakingdoms diagnosis seems to be the logical approach so we are going with that.
Oil filter adaptor was broken in half How would that cause excessive oil pressure?
Glad a new pump got it fixed. What did the autopsy on the old one reveal?
I do not know what I am looking for.
When I get a chance to disassemble the spring and piston I will update.Thanks
Removed roll pin and spring but when I tried to remove the piston it got stuck about halfway down its bore and I had to force it out with a coat hanger,Could this have been the issue?
