perfromance problem...
Old Jan 24, 2002 | 04:28 PM
Blade69's Avatar
ever since i did my first burn out it seems as if it did something to my car. it was running stronge as hell before i did it and know its running sluggish, and instead of 20mpg iam getting 10mpg. Do you know what it could be? maybe the fuel pump?
Old Jan 25, 2002 | 10:35 AM
Blade69's Avatar
ANYONE?!?!?!?!?!?!?!
Old Jan 25, 2002 | 11:43 AM
sleeper's Avatar
we need more info here... give us some clues...
is the car stick shift? maybe you burned the clutch. What about a sticky brake? burnt plug wire? maybe the superfluous coupling is damaged?
Old Jan 25, 2002 | 01:16 PM
Blade69's Avatar
i have a 5 speed 84 camaro with a 71 350. Right after i did it i noticed the performance loss and it started to shift way to smoothy, before i did it you could notice that there was alot of power every time i shift because the car would jerk a little, and it wasnt from not knowing how to shift, unless i got amazingly good after the burnout.
Old Jan 25, 2002 | 03:44 PM
Blade69's Avatar
Sleeper, any sugguestions???????
Old Jan 25, 2002 | 05:03 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
How high was the engine revving when you did the burnout? Did you hear any pinging at all?
Old Jan 25, 2002 | 06:12 PM
Blade69's Avatar
i didnt mean to but i think i got past the red line by a few hundred RPMs, and i dont recall any pinging.
Old Jan 25, 2002 | 06:18 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Thats is probably going to be a big part in the problem you are experiencing. You might have made the valves hit the piston.
Old Jan 25, 2002 | 07:13 PM
Blade69's Avatar
WHAT!!!!!!
if i did would it cause the horrible gas milage. Is this something that can be fixed if its the proplem??????
if so how hard would it be to fix it???????
Old Jan 25, 2002 | 07:40 PM
ChevyLuva3's Avatar
WHOOOAAAA!!! I got the same reaction!!
Thats insane, my bro did two burn outs with my car at different times, I still haven't, but I have noticed a reduction of power, and I too also get like 11mpg!! Seriously if he fvcked something up, I'm gonna fvck him up, big time!!!
But I really don't think no matter how high you raise the rpms the valves would never touch the piston, if it did your car wouldn't even run!!! The valves would be destroyed, and the piston would have a giant gash in it.
Plus, the faster the piston/crankshaft then the faster the valves/camshaft. So they would never contact each other.... unless you broke your timing chain!!
Old Jan 25, 2002 | 08:14 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You may have gotten enough rod stretch that you hit the head or the valve hit the piston. Just a thought. But I’d say it was something pretty major.
Old Jan 25, 2002 | 08:23 PM
sleeper's Avatar
Blade... if the car doesn't shift as hard as it used to then I suspect the clutch is slipping. This would cause crappy mileage.
I doubt there is any engine damage. Over reving would cause a knock in the lower end as well as lower oil pressure.
Time to inspect your clutch.
The 5 speeds don't have stops on the shifter fork meaning that it is possible to break things if you yank too hard
Old Jan 25, 2002 | 08:25 PM
sleeper's Avatar
this goes for other stuff too
Old Jan 26, 2002 | 12:56 AM
zroc's Avatar
Car: 87 IROC
Engine: LB9 for the moment
the phrase "floating the valves" comes to mind...
inertia overcoming the valve spring capabilities= smiley faces on the pistons and bent valves...
zroc
theshackle
Mar 5, 2017 06:37 PM
Daemorok
May 25, 2002 07:22 PM
tpivette89
Aftermarket Product Review
May 20, 2002 02:33 AM
wasp
Apr 26, 2002 12:27 PM
Blaze of Glory
Nov 20, 2001 10:18 AM
