Aftermarket In Tank Fuel Pumps?
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
I need to drop my axle to do suspension work anyway and I plan on putting in a bigger motor soon than my 350. I have the intake and injector for 650hp on the next motor, so to future proof the car I was thinking about the aeromotive stealth 340LPH, but I don't want to deal with upsizing the metal lines. Can I get away with 340LPH in the stock lines for a while on a motor that only makes 350-400hp or do I have to use the Walbro 255 for the time being until I bother to put new lines in?
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Aftermarket In Tank Fuel Pumps?
In theory yes but isn't the stock return only 5/16"? I imagine I would have a problem trying to flow that much fuel back to the tank with the pump being wildly oversized.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I have aem 340’s in my tank, basically directly replaced the walbro 255’s i had.
On stock fuel lines at EFI fuel pressures? Sounds like I have nothing to worry about as long as I have a good pressure regulator!
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
I have the aeromotive stealth 340L/hr. It's been great. It will feed up to 750hp if your na. I'd recommend having a return line that matches your feed. The smaller return can cause you pump to run hot.
Car: 89 Iroc-z
Transmission: TH400
BOTTLEDZ28
Jul 22, 2001 10:15 AM
