85’ Z28 stalls when breaking.
Old Aug 9, 2025 | 09:54 AM
Jdnuss02's Avatar
Hey y’all,
I have a 1985 Z28 with the TPI with about 95,000 miles on it, the other day I started stalling when breaking, sometimes it’s right before I get to a complete stop others will stall while I’m still at 20-30mph just depends on how fast I’m going. I checked the break booster by putting on the e-break, putting it in drive, and punching the break but it idles like normal. I couldn’t find a vacuum leak on any of the hoses as well. I do have a check engine light when I idle. I don’t really know what else to check so I’m coming to you guys. Any guesses?
Thanks.
Old Aug 9, 2025 | 10:03 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 85’ Z28 stalls when breaking.
What code is stored 24 ?
Old Aug 9, 2025 | 11:10 AM
Toon86's Avatar
Car: 1986 Base Firebird
Engine: 2.8L MPI
Transmission: 4 Speed
Axle/Gears: 3.42:1
This is how to check for error codes on the ECM if you don't have a code reader.
The ALDL or DLC is located behind a plastic cover under the steering wheel.
Diagnostic Mode
If the "Test" terminal is grounded (Jump pins A and B) with the ignition "ON" and the engine stopped, the system will enter the Diagnostic Mode. In this mode the ECM will:
1. Display a code "12" by flashing the "CHECK ENGINE" light (indicating the system is operating). A code "12" consists of one flash, followed by a short pause, then two flashes in quick succession. This code will be flashed three times. If no other codes are stored, code 12 will continue to flash until the "Test" terminal is ungrounded:
On fuel injected engines, codes can only be obtained with the engine stopped. Grounding the "test" terminal with the engine running gives the "field service mode".
2. Display any stored trouble codes by flashing the "CHECK ENGINE” / "SERVICE ENGINE SOON" light.
Each code will be flashed three times, then code "12" will be flashed again.
On a fuel injected engine, if a trouble, code is displayed, a Diagnostic Code Chart from the service manual is to be used to find a problem.
If you do not have a service manual let us know what code(s) you have and we will look them up for you.
Old Aug 9, 2025 | 11:20 AM
Jdnuss02's Avatar
not 100% sure I do not have a OBD1 scan tool. I’m going to try the paper clip method today and ground it the AB pins. I’ll let you know.
Thanks for the help.
Old Aug 9, 2025 | 02:15 PM
Jdnuss02's Avatar
Diagnostic Mode
Will this still work if my ECM isn’t holding any codes? Because the check engine light goes away after I start driving it again.
Old Aug 9, 2025 | 02:18 PM
Engine: Lb9
Transmission: M20
If the light is off there probably isn’t a stored code. If the light comes on during cruising it might be 32 for egr.
Old Aug 9, 2025 | 03:05 PM
Jdnuss02's Avatar
The light goes off when I start driving again, comes on when I idle.
Old Aug 9, 2025 | 03:22 PM
Engine: Lb9
Transmission: M20
The only way to catch that code that’s probably not related to the stalling is to watch a scanner or use winaldl see what malfunction code throws. Your stalling could be iac related or fuel related like a sudden pressure drop. Might start by cleaning the iac and setting iac minimum speed then double check tps setting if you adjust the throttle body screw.
Old Aug 9, 2025 | 03:29 PM
Engine: Lb9
Transmission: M20
https://www.thirdgen.org/tpimod2/
Old Aug 10, 2025 | 06:18 AM
Toon86's Avatar
Engine: 2.8L MPI
Axle/Gears: 3.42:1
It is also possible that your fuel pump relay has failed and the oil pressure switch is what is keeping the engine running. When you slow down the oil pressure may be dropping low enough to drop out as well, depriving the engine of fuel and stalling the motor.
Replace the fuel pump relay and if the problem goes away, you will have found the cause.
Then you will have to find out why your oil pressure is dropping so low. The oil pressure switch should be closed from about 6psi. and higher.
Old Aug 10, 2025 | 08:13 AM
Engine: Lb9
Transmission: M20
? your saying oil pressure is suddenly dropping under 4psi ?
i didn’t see a mention of hard start or no pump prime.Taking a parts cannon isn’t a good way to diagnose.
Old Aug 10, 2025 | 10:50 AM
Toon86's Avatar
Engine: 2.8L MPI
Axle/Gears: 3.42:1
A parts cannon is a bad way to troubleshoot, but I don't know how many tools the OP has, and a $30 fuel pump relay is a cheap and easy fix.
Stalling while driving is a problem I would want to fix as soon as possible and this eliminates a possible cause.
Old Aug 10, 2025 | 11:12 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
You can TEST a relay. Don't need to buy one to TEST the theory.
I agree that the symptoms that have been shared, do not point to the FP relay. To that end, I think if the OP is getting less than 4 PSI oil pressure while decelerating (or any time), he's got bigger problems than a relay.
OP needs to buy a <$100 OBD I SCAN TOOL so he can have a relationship w/his ECM and "see" what is going on.
Old Aug 10, 2025 | 06:31 PM
Jdnuss02's Avatar
I replaced the oil pressure switch a few months ago. I’ll check the relay.
Old Aug 16, 2025 | 08:12 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Vacuum leak thru the brake booster, maybe. Had a similar issue yearsss ago. Turned out, the diaphragm in the booster ripped, every time i pressed the brake pedal the engine would stall.
See if the car still stalls with the booster line disconnected/plugged.
Alexzcar
South East Region
Sep 5, 2022 08:22 AM
jrfan4ever
Feb 24, 2011 11:11 AM
cozhavok
Jul 27, 2005 09:26 AM
