Standard sbc water pump on a Vortec L31 long block?
Old Oct 17, 2025 | 04:43 PM
Mortorq's Avatar
Car: '88 IROC T5 Vert ‘13 Vette
Engine: 305 TBI
Axle/Gears: 3:08
Hello Sofa and other exalted gurus,
At the risk of getting flamed, when swapping from a ‘87 L69 305 to a ‘98 L31 Vortec 350, can I use the 305 water pump?
If I’m not mistaken, a Vortec engine (‘96-‘02)water pump is opposite rotation?
Can the old (a new 305 replacement water pump)be used & work correctly?
In my case, it’s going in a ‘87 Monte Carlo SS.
I’d like to keep it simple as far as the accessory component brackets, etc. if possible.
thank you
Old Oct 17, 2025 | 05:41 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Re: Standard sbc water pump on a Vortec L31 long block?
if you use V belts yes use the old pump
if you use the much better newer serpentine set up then you need a reverse pump.
Old Oct 17, 2025 | 09:36 PM
Airwolfe's Avatar
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Are you just swapping long blocks but keeping everything else stock 87 Monte Carlo under the hood?
Old Oct 18, 2025 | 12:23 AM
Mortorq's Avatar
Engine: 305 TBI
Axle/Gears: 3:08
Yes, swapping long blocks, but going non-computer QJet, Performer Vortec intake, non-computer HEI, smog pump delete, mid length headers.
Wanted to put this L31 engine in my IROC T5 vert, but there’s some issues found with a 400 sbc I purchased used.
Old Oct 18, 2025 | 07:19 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Iirc, some vortec engines don't have the waterpump bypass port drilled in the block.
In 1988 the waterpumps went reverse rotation on the f-body w serpentine belt.
just use the pump that works with your accessories
Old Oct 20, 2025 | 09:02 PM
Mortorq's Avatar
Engine: 305 TBI
Axle/Gears: 3:08
Thank you guys!
Old Oct 22, 2025 | 12:48 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
As was previously stated, the water pump goes with the accessory belt configuration. Both design work with the L31 motor.
The comment on the bypass is true no matter which style water pump you use. You will need to plumb in a bypass for the L31 block.
Old Oct 22, 2025 | 10:07 PM
Mortorq's Avatar
Engine: 305 TBI
Axle/Gears: 3:08
TransAmGTA350…..
I have read the following, on the interwebz of course lol.
If (2) or (3) 1/8” or so holes are drilled in the t’stat that could serve as a bypass on a Vortec L31?
Old Oct 23, 2025 | 08:00 AM
Car: '89 GTA
Engine: ZZ6TPI
TransAmGTA350…..
I have not done that, but I have also heard that it works.
Old Oct 23, 2025 | 10:50 AM
Make sure the little bypass hole on the pass side of the WP is plugged where it goes against the block. If the block isn't flat there (should be, butt in case it's not) plug the hole in the WP.
For an actual bypass, put a hose nipple in the fitting on the top of the WP, and hook it to another one on the front of the intake. Make it small, like 3/8" hose or something; since it "bypasses" the pump's function of pumping coolant through the radiator, it only needs to be large enough to keep the WP from cavitating or otherwise misbehaving. The one you're replicating, between the WP and block, is only about that size anyway.
Old Oct 23, 2025 | 11:23 PM
Mortorq's Avatar
Engine: 305 TBI
Axle/Gears: 3:08
Thanks Sofa!
Sure appreciate your specific details.
Doppelganger
Mar 8, 2024 06:56 PM
budowski
Jul 19, 2017 09:57 PM
TayTayMurphy
Oct 14, 2014 08:16 PM
R.O.B.
Jan 15, 2004 04:36 PM
1tinindian
Apr 15, 2003 10:26 PM
