1984 Camaro no crank no start
Old Apr 27, 2026 | 09:59 PM
Mr.Freshies's Avatar
Car: '84 Camaro
Engine: 350 V8
Hi all, a while back I was testing my ratchet shifter by b&m installed by the previous owner, turned off the car, then it wouldn't turn back on. Few weeks later here I am trying to fix it.
So far I took out the starter and tested it on a power supply, it was good. Tested the neutral safety switch by putting the car in reverse and sure enough the reverse lights came on. I dont really know how to check anything else honestly.
When I go to start the car it just buzzes at me. A really loud and annoying buzz.
Old Apr 28, 2026 | 11:38 AM
Re: 1984 Camaro no crank no start
Sounds like bad connections in the battery cables somewhere. Possibly the batt itself.
Not a problem with the starter circuit in the car.
Old Apr 28, 2026 | 12:13 PM
Car: '84 Camaro
Engine: 350 V8
Ill check it when I get home (at the recruiters office right now) my 92 chevy 1500 just blew up yesterday but has a good battery, could I use the battery from it?
Old Apr 28, 2026 | 12:21 PM
LLCooLM495's Avatar
Car: 1992 Firebird
Engine: 3.1L LHO
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
If the 1500 uses side posts, should bolt up just fine. Might not fit in the tray, but would be good enough to test at least if it has the side posts. Also, if you have a multimeter, you can just check your battery to see if it's got roundabouts 12v.
I wonder though, since you said you checked the starter separately... I wonder if it could be VATS acting funny, I've had it wig out on me at random a couple times over the last decade... checking battery first is a good start though.
Ignore that, somehow completely looked over the fact that you have an '84, VATS didn't exist yet
Old Apr 28, 2026 | 12:43 PM
scottycamaroz28's Avatar
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
sounds like the issue is coming after you had some fun with the aftermarket shifter so I would start there. Having used and installed a couple B&M ratchet shifters I can tell you that there are 2 switches on the shifter. The one switch is for the reverse lights whch you have verified works. I would check the other switch on the shifter. It has 2 detents on it that allow the car to start in both park and neutral. First check to make sure the switch is plugged in, second make sure it is making contact in the correct shifter gears (a problem I have had a few times) because the switch is adjustable. And lastly if everything checks out test continuity of the switch. Or if you want to eliminate the whole shifter assembly as a whole, make sure car is in park, jump the neutral safety switch circuit on shifter and see if it starts that way?
Old Apr 28, 2026 | 12:56 PM
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Seems like a pretty cut/dry troubleshooting solution. You did X and Y happened immediately after. Time to look at anything related to X that affects Y. IE the neutral safety switch.
Old Apr 28, 2026 | 01:35 PM
Car: '84 Camaro
Engine: 350 V8
So I just checked the battery and its holding at 12.47 volts, cant be that. And on the b&m ratchet shifters can you tell me where the second switch is? All I see is one switch with 2 contacts to the shifter. And is there a way I can bypass the nss to start the car? (I have tried wiggling the shifter when starting and that did not work)
Old Apr 28, 2026 | 01:41 PM
How so?
What is the voltage WHILE IT'S IN THE ACT OF SCREWING UP? That is, when you're watching your meter and you have your assistant turn the key and IT SCREWS UP, what then? What's the voltage across the terminals themselves (if you can get to them), and what's the voltage across the cable ends, WHILE IT'S IN THE ACT OF SCREWING UP?
I cannot emphasize the importance of getting data from what happens WHILE IT'S IN THE ACT OF SCREWING UP. Data obtained while it's NOT ACTUALLY IN THE VERY ACT OF SCREWING UP is largely useless.
Of course. Butt you don't need that for anything. All that stuff is working fine. Your problem is MUCH closer to the battery.
Old Apr 28, 2026 | 01:46 PM
Car: '84 Camaro
Engine: 350 V8
Ah, thank you, Ill try to get those readings because Im still trying to get this battery out of my truck
Old Apr 28, 2026 | 01:49 PM
Car: '84 Camaro
Engine: 350 V8
Battery stays above 12v when I turn the key
Old Apr 28, 2026 | 01:56 PM
Car: '84 Camaro
Engine: 350 V8
Update: tried new battery same issue
Old Apr 28, 2026 | 02:32 PM
Engine: 5.0 TPI
On the switch it should have 4 leads on it because it is a double micro switch, 2 for the reverse and 2 for the nss, I would remove the shifter handle, boot and shifter plate so all you can see is the actual funtioning parts. Watch the mechanism move and see whcih one of the leads makes contact with detents that fall in park and neutral. You should be able to hear the switch and see the switch funtion if you move it slowly between P,R and OD. Once you isolate which side of the switch is the nss you can unplug it and jump the leads. Like before make sure the car is properly in Park or Neutral prior to trying to start it.
Old Apr 28, 2026 | 02:40 PM
Engine: 5.0 TPI
B&M Automatic Pro-Ratchet Shifter | Universal
you can see the switch in this picture. it looks like the top 2 leads follow along with one button and go for the reverse lights and the bottom one has 2 buttons meaning that little lever gets pushed in 2 position Park and Neutral.
Old Apr 28, 2026 | 02:54 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Worked on aftermarket shifter and now car won't start. It has nothing to do with your reverse switch. You did something to the neutral start switch.
Old Apr 28, 2026 | 03:29 PM
Car: '84 Camaro
Engine: 350 V8
Ill go out and test the nss now, but how would I jump it?
Old Apr 28, 2026 | 03:50 PM
Car: '84 Camaro
Engine: 350 V8
When I manually manipulate the reverse portion of the switch I hear a click but when I manipulate the neutral portion there is nothing, is the switch dead or is that normal?
Old Apr 28, 2026 | 03:54 PM
Car: '84 Camaro
Engine: 350 V8
YALL ARE AMAZING ITS THE SWITCH
Can't believe it was that easy, thank you guys so much
Old Apr 28, 2026 | 03:58 PM
Engine: 5.0 TPI
AWESOME! so you could jump that switch with jumper wire. Or go online and buy another one. there are 2 switches there stacked on top of each other. just make sure you adjust them to make contact properly after install. Alternatively you could wire those leads to you own hidden kill switch?
Old Apr 28, 2026 | 05:10 PM
Car: '84 Camaro
Engine: 350 V8
I actually just got done i stalling it as a killswitch lol, I got it hidden in the ashtray
Old Apr 28, 2026 | 05:32 PM
Engine: 5.0 TPI
You just gave away your secret! Now if you could just post your address for a secret joy ride I think that should square us all up! Haha
Vinscully50
Jan 24, 2020 05:11 AM
FreeSpirit
Sep 19, 2012 04:13 PM
howard618
Aftermarket Product Review
Dec 22, 2011 09:22 PM
Rich92 RS
Aug 3, 2008 09:10 PM
Sonicbluecamaro
Oct 13, 2007 04:32 AM
