Rear tube on headers get red hot, why?
Old Jan 26, 2002 | 01:51 PM
FoREEL's Avatar
The other day I was lookin in my engine bay and I noticed that my rear headers the number 3 cyl and number 8 cyl where red hot. Whats up with that?
Thanks Chad
Old Jan 26, 2002 | 02:18 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe there are one of 2 reasons. Running lean or a restriction in the exhaust. Is your cat glowing as well.
I'd check your timing.
Old Jan 26, 2002 | 02:30 PM
FoREEL's Avatar
No it definitely isn't a restriction I don’t have a cat. I do know that if its running rich then your cat will be red hot so I bet your right that its running lean. Any sug. on that?
Old Jan 26, 2002 | 02:34 PM
FoREEL's Avatar
No it definitely isn't a restriction I don’t have a cat. I do know that if its running rich then your cat will be red hot so I bet your right that its running lean. On the timing I just recently replaced my intake manifold and had to set it for that, so it should still be set from doing that. What would it do if timing was off? Any sug. on it running lean??
Car: 99 Formula
Axle/Gears: 342
Check your timing and if it's carb your choke.
Old Jan 26, 2002 | 04:50 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Could be a intake vacuum leak causing a lean misture in those
two cylinders. On a dual plane intake manifold, they share a common plenum. Look for vacuum hoses, carb base gasket, intake manifold gasket, transmission vacuum modulator leaks Power brake vacuum booster leak.
Old Jan 26, 2002 | 11:15 PM
breathment's Avatar
could it be maybe your not getting good spark in those cylinders? maybe check ur wires and plugs to make sure they're in good shape.
Old Jan 28, 2002 | 09:23 PM
FoREEL's Avatar
Thanks All
Old Jan 29, 2002 | 08:58 PM
Coxy's Avatar
Car: 91 RS B4C
Engine: 355
Transmission: TH 350
I would say definatly a lean problem. I built my motor last year and lent my brand new holley 750dp to a bud for the track, his motor sat at an angle and I didnt realize he had the floats so f..... up, any way when I lit my new motor it was way lean and f..... my new ceramic headers up, I immediatly shut her off found the prob and life is good.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
MORREALE5
Sep 13, 2015 09:16 PM
Leggman1
Aug 6, 2015 04:15 AM
