poping in exauast
Old Jan 29, 2002 | 11:58 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
poping in exauast
I have a 350 with edelbrock 1000cfm EFI, comp cams 280h cam (230* at .05 lift) trick flow heads, and various other goddies the problem is that when the engin is cold the exauast sounds like a popcorn poper at partal throttel once it warms up it runs fine but it's annoying letting it warm up for 15 min to take a 2mi ride across the airbase. anybody know why it dose this and a fix for it???
Old Jan 29, 2002 | 02:17 PM
Engine: 383
anybody?
Old Jan 29, 2002 | 05:22 PM
Lowflyer's Avatar
Popping noises out the exhaust sounds like you're floating valves. I assume you had your valve springs matched to your cam and rockers, right? When it does this, is there a miss at high RPM? Could be weak springs...
Is it doing this when the ECM is in Open loop and goes away at Closed loop? Could be a timing problem in the closed loop program. How much timing do you have dialed in at open loop?
Keep us posted and good luck.
Old Jan 29, 2002 | 06:13 PM
Engine: 383
It dose it when I first start the engine and it lasts for about 10 min. if I floor it it dosen't do it only when I try to keep the same speed (25mph on base-about 2000RPM) once It warms up it stops- but not warm enough for it to go into closed loop. Could it be the lifters or the rocker arms? I have crane variable duration lifters and summit roller rockers. the valve springs are the ones that came with the heads wich are the higest seat pressur ones that were avalible and there brand new so I don't think I'm floting the valves(I don't have my summit catalouge handy-I'm at work) I was also wondering could this be related to my header gaskets blowing out alot recently? Thanks for your help.
Old Jan 29, 2002 | 06:19 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
When I had a burnt plug wire and when the car was cold if I gave it too much gas I would get a backfire thru the carb.
Old Jan 29, 2002 | 06:25 PM
Engine: 383
no it's not that because it's doing small backfires out the exaust but thanks anyway
Old Jan 29, 2002 | 09:43 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
poping in exauast
Thanks for the great typo!!!!! I've heard of shoving a potato in the tailpipe, but poping? That would hurt if you lost your balance!!!!!! LMFAO!!!!!
I know you didn't mean it, but it was a very needed laugh!!
Kinda reminds me of that dog that Conan O'Brien has on his show.
"That's a nice exhaust you have...... FOR ME TO POOP ON!!!!"
Thank you,
AJ
Old Jan 30, 2002 | 09:29 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Is it coming from the back of the car, or up by the collectors? You could try moving the timing up or back by say 3* to 9* to see if that has an effect. If that helps it would be a good indication that the timing maps are off at that load RPM. I wouldn’t drive with the timing advance or retarded by that much for long as it may cause other problems.
Old Jan 30, 2002 | 10:37 AM
Engine: 383
It's comming from the headers. I already tryed to play with the timing and fuel curves alerady and it had little effect. I also just blew out another header gasket last night I was also wondering if it could be exaust restriction - I have 1 5/8" primaries that go into a 3" collecter that y into a 2 3/4" intermeadiate pipe and ends in a flomaster muffler-, that is going to be changed to true duals (2 3/4") with no cats when I get my taxes back.
Old Jan 31, 2002 | 02:39 PM
Engine: 383
just returning this to the top:hail:
Old Feb 1, 2002 | 07:24 AM
NEEDAZ's Avatar
Car: 89 IROC-Z
Engine: 355 TPI
Other then header ping I’m out of ideas. Header ping is usually not that loud though.
Old Feb 1, 2002 | 07:42 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
change your distributor cap, mine did the exact same thing.
Old Feb 1, 2002 | 08:54 AM
GreenProStreet's Avatar
GM High Tech Performance had to change there springs to Comp ones for the same reasons, on their 396 Lt1. It this is the case, than you may have toasted your pushrods as well. Check them against a straight edge, if you need to change your springs.
Old Feb 3, 2002 | 06:08 PM
Engine: 383
I just stoped the problem the #7 spark plug had backed out and I thought it was a header leak I found it when it still ticked after the gasket change- the poping stoped (still don't understand how) but I have a new problem that I am about ta start a new thred about.
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
RPS
Jun 14, 2002 07:02 PM
92 z28
Jul 2, 2001 01:50 PM
92 z28
Aftermarket Product Review
Jul 1, 2001 09:07 PM
