My heat doesn't work to well.
Old Jan 29, 2002 | 06:20 PM
AFRO IROC Z's Avatar
I have a quetion about my heater core. I changed my heater core this summer, after 2 years without out heat( that was fun ). Well when i was finished and put everything back together i noticed that the wire that hooks up to that little door, the one that opens and closes the heater core off, was broken. It is located under the passenger side kick panel. I hope someone knows what i am talking about. Anyway i had to rig something up to make the door open and close but I don't know if the door is opening or closing all the way. I say this because the heat coming out of the vents isn't very warm and I remember before the heater core went bad I really didn't even have to have the heat on just the temp adjust lever set to hot. So my question is, is there any way to know if the door is closing all the way without tearing the dash apart. I could have swore that before i tore the dash apart I could hear the door opening and closing. If someone could tell me if I am correct or not I would appreciate it. Thanks
Old Jan 31, 2002 | 01:45 PM
ttt
Old Jan 31, 2002 | 02:01 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Try moving the lever to both extremes of it's travel. You should be able to hear the door "thump" shut.
Also, there should be some resistance to movement, if it moves really easy, well, you need to tear into the dash.... Sorry.
Something else to consider is, is the heater core getting good flow? I replaced mine, only to have it get plugged up a year
later... (makes it kinda cold.....)
Have fun.
Old Jan 31, 2002 | 02:08 PM
rezinn's Avatar
I'd take the kick panel off and have someone move the adjuster around to see if the door moves.
Old Feb 9, 2014 | 09:21 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Engine: LT1 conversion
Transmission: Rebuilt 700r4 w/2400 stall
Axle/Gears: 373
Re: My heat doesn't work to well.
I know this post is really old but I'm having the same issue and believe the cable that opens and closes the heater core door is broken. The hot/cold lever moves way to
easy and I don't hear any thumping noise like you should hear when moving that lever back and forth. Does anyone know where I can get a new one or will I have to rig something up?
Also will I need to remove the dash to do this job?
Any suggestions would really help.
Old Feb 14, 2014 | 12:58 AM
John62591's Avatar
Car: '83 Camaro Z28 5.0, '93 Camry 3.0
Engine: 305 V8, V6 DOC
You can try RockAuto.com, Autozone/Oriellys, or a junk yard. I have a feeling I may be doing this with mine too... Hopefully You don't need to remove the dash. I'm gonna get some sleep, but maybe tomorrow or by Monday I will post back and take a look at ALLDATA for it. And the door your talking about I believe is called a blend door, which moves air into different vents in the car. If its broken it may block the hot air...
Good Luck..
Old Feb 14, 2014 | 01:56 AM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
Ok thanks, let me know if you find out any further info with your project. Take care
Old Feb 28, 2014 | 03:00 AM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
Hey John did you ever get into your blend door issue?
Old Mar 1, 2014 | 12:17 PM
John62591's Avatar
Not yet, I do school in the day, some nights. Some weekends I have little time. Too much snow for washington this time of year too.
Old Mar 1, 2014 | 12:23 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
U can try removing the heater core hoses and blow it out backward with water hose .. it worked for me
91' firebird .. 305 TBI .030 over , balanced bottom end , speed pro hyper flattops , 10.6:1 CR , all ARP rod bolts and main studs , melling HV oil pump , trick flow super 23 175cc heads, Howards HR 214/218@.050 .488/.495 lift on 114 LSA , full roller 1.6 RR = .520/.528 lift , summit dual plane intake port matched , shorty headers into 2.5" Y w full 3" flow master system and 3" cutout in front of axle , msd billet dizzy, 620cfm TBI , custom CAI , tubular adjustabke LCA pan hard , umi torque arm wonder bar , BMR trans cross member , COMP engineering SFC's, disc rear w 4.10's, drilled an slotted rotors, EBL flash , VRFPR, WBO2,
Old Mar 1, 2014 | 12:38 PM
John62591's Avatar
My issue is mostly with the air only going through the defrost vents only, but i found a TSB (Technical service bulletin) that says I have a pinched HVAC vacuum hose.
Either way I will still be taking the dash apart. I will probably take pictures of the teardown and post them here, since taking the dash out means you can fix your issue too.
Old Mar 1, 2014 | 01:02 PM
John62591's Avatar
I have two cars that I need to do that to. Thanks for reminding me.
Old Mar 1, 2014 | 02:18 PM
JohnnyT/A's Avatar
Car: 1987 Transam
Axle/Gears: 373
I recently blew out the heater core. I did clear out some gunk however it still didn't fix the issue of not having any heat. I too have check out the blend door and hopefully that will solve the problem
Old Mar 1, 2014 | 09:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That is the default position ; you have no vac from the engine to the controller
Start by checking the one way valve on the engine before you rip anything apart.
Common for it to break with age
Old Mar 3, 2014 | 11:45 AM
John62591's Avatar
Alright I will, that's a good idea, I believe it's relatively cheap if I do need it replaced anyways.
Old Mar 3, 2014 | 11:54 AM
John62591's Avatar
I have the center console out, so I can figure out the radio wiring, But I'll be putting in speakers from my old car temporarily. I'm doing a few things to the dash/interior with the lights to rewire/clean.
I have a couple pics of the heater control and the cable that is hooked up, but when I get the dash apart a little more I'll get them posted here.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Randomtask2
Aug 13, 2015 01:57 AM
