stock coil ?
Old Jan 30, 2002 | 07:25 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
stock coil ?
when does the stock coil start putting out lower voltage?
Old Jan 31, 2002 | 01:53 PM
ChevalierSS's Avatar
Here is a tip for anything electrical; they can go bad at any time. Somethings only last 2 weeks, others last forever.
Old Jan 31, 2002 | 02:05 PM
deadtrend1's Avatar
ive noticed on a weak coil, it produces a small yellow spark when grounding a plug to the engine block. Also its hard as heak to kick over too.
Old Feb 1, 2002 | 01:35 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
May need a new cap, rotor, wires or any combo of them? Have you inspected them yet?
Old Feb 2, 2002 | 06:18 PM
TBI305Camaro's Avatar
i stuck a new hypertech 53,000 volt coil, cap, and rotor on my car and noticed a huge difference my stock rotor,cap, and coil had over 100k miles on them. also when i got the car 5k miles ago it had the stock wires and everything so i replaced it all and it runs really good now
Old Feb 2, 2002 | 06:55 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: stock coil ?
From what I getr from your question, the stock coil stops producing noraml spark around 5500rpm. This of course is . An aftermarket coil will give you more juice through your operating RPM but if you old coil is still in good condition you wont notice any difference in power.
SSC
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Thirim
Aug 13, 2015 03:09 PM
