cam bearings
Old Feb 6, 2002 | 08:58 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
cam bearings
is it completely necessary to chang cam bearings when i put a new cam, intake, and heads in? the motor has about 70,000 miles on it
Old Feb 6, 2002 | 09:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
cam bearings are normally changed only during rebuilds
the cam turns at 1/2 crank speed so they last 100K+ miles. Just be carefull and dont gouge them putting the new cam in.
bolt the top gear on temporarly to help hold a good grip on it during install
Old Feb 6, 2002 | 09:20 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
no as long as they appear alright, you should be fine. however if you were going to do i complete rebuild i would suggest you get the block dipped and hot tanked, new cam bearings and freeze plugs.
Old Feb 6, 2002 | 09:24 PM
okc305's Avatar
I dont know how necessary it is to chang the cam bearings, but they are only 15$ at summitracing.com. However i dont know how easy it is to change the bearings your self? i got my changed at the machine shop when they bored my block. I would ask someone that is more knowledgable about that. Any way the part # at summit is CLE-SH1349S. Sorry if i didnt answer your question. good luck with the cam, intake, and heads.
Old Feb 6, 2002 | 10:05 PM
Hellraiser's Avatar
Installing new cam bearings isn't something you want to attempt with the engine in the car. So if you're plans dont involve pulling the whole motor, don't even worry about it. Just add the cam.
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
