do I have long or short water pump
Old Feb 9, 2002 | 08:28 PM
89blackbird's Avatar
Simple question Do I have a long or short water pump? I have an 89 GTA with 5.7 . I want to replace the old one when I do rebuild.
Old Feb 9, 2002 | 08:41 PM
Fbird88's Avatar
Car: 1988 Firebird
Engine: GM Performance Parts 350 HO
Axle/Gears: :(
Long
You have a reverse-rotation, long water-pump.
Old Feb 9, 2002 | 09:10 PM
Reverse rotation?? I don't see that listed in Jegs or Paw I will look again.Thanks.
Old Feb 9, 2002 | 09:38 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I think the one reverse rotation the carry are aluminum Edelbrocks, but they're there
Old Feb 9, 2002 | 09:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just because Jegs, PAW or Summit don't list it, doesn't mean it's not available. They only list a small portion or their stock. It's best to just call and ask them.
Example. Look at all the cams they list for Crane or Comp then look in the Crane or Comp catalog. All those cams are also available from the mailorder houses but they won't list them all.
Old Feb 9, 2002 | 10:23 PM
My mistake PAW has it listed. Thanks again
Old Feb 10, 2002 | 04:11 PM
Chevy83Z28's Avatar
I've heard of JEG's and Summit but what's PAW? I tried www.paw.com and got some research site... what's the url for paw if it's another performane parts source? Thanks guys.
Old Feb 10, 2002 | 05:34 PM
EROCK's Avatar
Does my 91 LO3 Camaro have the same? I have been wondering that for a while now. I don't think it is reverse flow though.
Eric
Old Feb 10, 2002 | 06:19 PM
Dingo's Avatar
The serp belt spins the water pump backwards compaired to a V belt small block so your L03 should be reverse flow EROCK. Also they stopped using the short in the 60s (I think) exept for a few applications (read Vette). Please correct me if I'm wrong, Knowing me I am.
Old Feb 10, 2002 | 06:24 PM
camaro6spd's Avatar
WHOA!!!!, LT-1s use reverse flow. we use standard flow.
Old Feb 10, 2002 | 06:33 PM
Jza's Avatar
Jza
standard flow, reverse rotation.
Old Feb 10, 2002 | 06:44 PM
Dingo's Avatar
Thats what i meant. Told you i'd screw something up on that.
Old Feb 10, 2002 | 07:06 PM
PAW stands for Performance Automotive Wholesale www.pawengineparts.com
Old Sep 28, 2008 | 09:58 PM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Re: do I have long or short water pump
I'm about to purchase a Meziere water pump for my '89 GTA and it lists it either with or without the heater and bypass ports; which one should I buy for my car? Thanks in advance.
Phoenix
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 24, 2015 09:12 PM
Dialed_In
Aug 20, 2015 01:45 PM
