air box modification
Old Feb 10, 2002 | 02:29 AM
z28-92's Avatar
I have a '92 Z28 350 with TPI. When I was installing my K&N's a while back, I noticed that the airbox had these funky baffles in them, kind of like a curved platic curl which I would thick restricts the airflow somewhat. I'm guessing they did this so that the intake wouldn't directly suck in any moisture? Any one ever remove these baffles and experience any problems or are they negligible and not worth the effort removing.
As another thought, are there any advantages of going with the K&N open air element mounted on the TB? I would guess that it would be less restrictive but would suck in alot hotter air?
any thoughts?
Old Feb 10, 2002 | 02:57 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yeah. Take the baffles out. U are right about the filter on the TB, it wouldn't be good. Unless u have a hood like an SS hood that is open there for air to get right to it and not closed like the stock hood.
Old Feb 10, 2002 | 04:30 AM
Vader's Avatar
92,
Good call - There you guys go, using logic and reason again... When will this madness end?
If you want to get a few more ideas for mods, check near the top of the Tech Article section at the front of the site: https://www.thirdgen.org/newdesign/tech/
The gutted air box is just one of those modifications done routinely, and most suggested mods have adequate detail to make it fairly clear.
BTW - Welcome Aboard!
Old Feb 10, 2002 | 05:17 AM
z28-92's Avatar
Thanks for the info and responses. I wish I'd found this place 10 years ago when I first bought my car. You guys are a wealth of information and this site is truly addicting.
Thanks,
Old Feb 10, 2002 | 12:44 PM
z28-92's Avatar
BTW, when I remove the baffles, do they just snap out or do I have to cut them out. I haven't had a chance to get in there to look and thought I'd ask since it sounds like this is a common free mod.
Old Feb 10, 2002 | 01:31 PM
LeftTurn1LE's Avatar
Yes, take out the bolts and they just lift out.
And you are right about this place being addictive. If I'm at home, I am probably on TGO.
Old Feb 10, 2002 | 01:36 PM
87_Camaro's Avatar
i myself had a 87 MPFI camaro with the same intake as the TPI's i just gutted the intake boxes, " cut off the bottoms" so the air fiters will get max air flow and you will get a great improvment in response & horse power, you can also take it a step further and leave a little bit of the boxes "to where theair slits were" and then get 8 inch air conditioner tubes and make a ram air/ cold air intkae out of it, works great there is a tech article on making them, you should check it out.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
dyeager535
Aug 28, 2015 08:10 AM
bryan623
Aug 10, 2015 11:33 AM
