Ever try to fix something and end up breaking something instead?? Need help.
Old Feb 11, 2002 | 04:25 PM
AFRO IROC Z's Avatar
Okay, today i decided to try and fix the light for my high beam indicator. I thought that maybe the bulb was loose or something. Well I didn't know if the needle for the speedo could come off or not. But i got it off alright, broke it right off . Now i can't tell how fast i am going . i can kinda guess but i would like to fix it if I can. So my questions do i need to get a whole new little speedo assembly or can i just go get the needle and the pin it presses on to and use that. I mean if i take the assembly apart will that mess it up. If i need a new one do i need one with the 140mph speedo because that is what i have. Does it have to be from an 87 camaro which is what i have or can it be from a firebird. Plus if there is anything else that i should know i would really appreciate it. Also is there a right way to take the needle off or is it like that to prevent tampering . I mean there has to be right or how do people put on white face guages?? Thanks for any help you can give me.
Old Feb 11, 2002 | 04:35 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
If you only broke the plastice needle and not the metal shaft it sits on, then you can just replace the needle by itself. If you broke the shaft you will have to fix/replace the speedometer unit but not the whole cluster. If you replace the speedometer unit then it will have to be out of a car with the 140mph speedo. To get them off with out breaking them, I pull it off by the circular part and not the needle and just do it very carefully.
By the way, to change the lightbuld you DO NOT need to take the needles off, the bulbs are in the back, and they twist out.
John
Old Feb 11, 2002 | 05:51 PM
Do you know if i can get that part through gm and would you happen to know how much, Yeah I know the bulbs come out through the back i just don't want to tear the dash half apart to get to it . You can't really get to the back of the cluster without disconneting the speedo cable and i could barely fit my arm back there when i had it torn apart. I really appreciate your post, thanks.
Old Feb 11, 2002 | 06:55 PM
mcconahay37's Avatar
Perhaps you should do a search for the thread "What NOT to do when working on you car". You aren't alone.
Old Feb 11, 2002 | 11:13 PM
I would bet that part is discontinued just like everything else is for the most part I would go to the local u-pull-it junk yard and just pocket one. Most of the time even if you show it to them, they won't charge you for something that small. As for tearing the dash apart, On mine which is electric there is about 3 trim panels you need to take off, and then the cluster comes out with like six screws. One at each corner, and one in the middle at both the top and bottom of the cluster. It should only take about five minutes to do!
That post was hilarious!! (some of it was unfortunate though )
Old Feb 11, 2002 | 11:49 PM
So are you saying that i don't have to disconnect the speedo cable? I can just unscrew it and disconnect it once the assembly is unscrewed, then connect the cable to the new assembly and screw it back in and then i am done? Just want to be sure before i tear the dash apart. My car is an 87 iroc. when you said your dash was electric did you mean digital?? Mine is not(digital). Anyone know if the speedo assembly can be replaced without tearing the dash apart?? Thanks.
Wylecoyote08
Aug 22, 2015 01:58 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
sonu1975
Aug 11, 2015 08:38 AM
Bull86
Aug 10, 2015 05:43 PM
