Valve springs for LT1 cam
Old Feb 12, 2002 | 12:45 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I just got an LT1 cam off ebay. Now I know the stock springs won't be good for it. What springs would you recomend. Also should I put the cam in or should I do the cam, heads and manifold. The latter two I have not purchased yet. I'd do all three at same time. Just worried that if something isn't right after I am done(which always seems to be the case) there would be less to look at. I have yet to ever change a cam heads or manifold.
Thanks in advance,
Chris
Old Feb 12, 2002 | 01:33 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Actually the stock springs with 1.5 rockers will handle the LT1 cam just fine. It wont handle 1.6 rockers however...
Old Feb 12, 2002 | 08:40 PM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Yeah, but if you're at or near 100k, maybe new springs wouldn't hurt, especially since the LT1 cam would wear out the stock springs even faster than the stock cam, right? Looser springs = valves float at lower rpms...
I just bought tighter springs for my L03 LT1 cam swap: K-Motion K-700 springs (115# closed, 350#open).
Old Feb 12, 2002 | 11:07 PM
Car: 92' RS
Engine: LO3
Will this cam make the exhaust sound more aggresive?
I know the LT1 cam is certainly not agrresive, but it surely is more aggresive than the peanut cam.
Old Feb 13, 2002 | 12:29 AM
Car: 91 Formula
Engine: 305 TBI
Why do people here keep calling the stock cam "the peanut cam?" I keep seeing this... I know it isn't a performance part by any means, but why "the peanut cam?" Do the lobes resemble peanuts more than those of other cams or something?
Old Feb 13, 2002 | 12:31 AM
Car: 92' RS
Engine: LO3
its called this because the lobes are so small they are as big as peanuts
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
