Is a 1/2 ton engine stand good for small blocks??
Old Feb 14, 2002 | 02:20 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I'm not sure about the weight of engines. Would a 1/2 ton engine stand be good for small blocks?
Old Feb 14, 2002 | 02:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I don't know for sure, but my guess would be there's no way an engine especially a SBC weighs more than 1000lbs.
Old Feb 14, 2002 | 04:05 PM
LottaBallsCamaro's Avatar
You could hang a bigblock on there with no trouble.
Old Feb 14, 2002 | 04:27 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
See that was the thing I've seen 2 ton engine stands I know an engine doesn't weigh that much but still
Old Feb 14, 2002 | 04:40 PM
Car: 99 Formula
Axle/Gears: 342
2 Ton stands are for if you want to rebuild a VTEC....
Old Feb 14, 2002 | 05:26 PM
89blackbird's Avatar
Really it depends on the stand. I purcased a 1250 lbs stand and it was a bit shakey for me. i mig welded it where it was bolted together and it made a world of difference. I think the manf. push the truth a bit. If the stand looks and feels cheap it is. Thats may 2 cents.
Old Feb 14, 2002 | 05:42 PM
ronterry's Avatar
Car: '94 Corvette
I don't mess around with cheap stands. I bought a four-wheel stand that is a hell of lot more stable then a three-wheel stand.
This comes true when you start moving the engine around, or even rotating it.
Grade 8 bolts are also the way to go, when attaching it to the engine.
1/2 ton should be enough, even if you bolt up all the accessories.
I also liked what "89blackbird" did, by welding the joints. You could probably even weld some 45-degree gussets to increase its capacity two fold.
Ron
Old Feb 14, 2002 | 05:56 PM
Beast4's Avatar
Second the recommendation to go with a four wheel stand. Three wheel stands are entirely too unstable, especially when torquing head bolts etc.
Old Feb 14, 2002 | 06:15 PM
I forgot but you are right all the way with 4 wheels.
Old Feb 14, 2002 | 07:18 PM
ronterry's Avatar
Car: '94 Corvette
Cool, it does make a hell of a difference when the old lady tells you to move the engine out of the kichen ...
It's a different story when she tells me to get the transmission out of the tub !
BTW: I ment 90-degree gussets.
Ron
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
