wich spark plug
Car: 99 Formula
Axle/Gears: 342
Don't waste your money on fancy plugs. Regular AC Delco are just as good. Also platinums last longer but the spark isn't as good.
so when they advertise that a "multiple spark plug path" is actualy good for combustion in the chamber its a load of
???? what about their claims of increase in milage and quicker starts..more
???isnt that false advertising?
???isnt that false advertising? Supreme Member
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I just recently switched from bosch platinums to AC delcos. The bosch keep fouling out, I went thru a few sets. I have an MSD system.. it looked like the platinum was melting on the ceramic tip.
Havent had any problems with the AC plugs yet.
???isnt that false advertising? Trending Topics
Car: 91Z28 L98
Engine: HSR 350
Transmission: Goebel 700R4
I know in aircraft piston engines, there are two plugs per cylinder (two ignitions systems per engine, too). Both plugs fire simultaneously (duh), but when checking each system, you turn one off and make sure the engine runs well on only one, but you do lose about 50-125 rpm by only having one plug fire rather than two (less complete fuel burn). Is this similar to the claim that these plugs make. But actually, the current will take the path of least resistance, so you only get the spark going from the electrode to one of the thingamajiggers (???? for lack of knowing the technical term). So you wouldn't really be getting multiple sparks, would you??? The only thing I could see would be if one fouled and then it would use the other.
P.S. I just put in Bosch Platinum and am worried about fouling....pray for me.
Hey Mark... can ya do me a favor and take a picture of your front blinkers when off, and then another pic of them on (like low beams) I would like to see how well the light shines through the Night shade... Thanks!
Originally posted by iceman02
... when checking each system, you turn one off and make sure the engine runs well on only one, but you do lose about 50-125 rpm by only having one plug fire rather than two ...
That is correct. And did you ever notice how when you're testing the mags the RPMs always drop compared to the breaker point or CD ignition system? Wierd, isn't it?
The other differences to remember are that the Lycomings and Continentals are usually way over 500 inches in displacement, and have huge friggin' chambers and low compression heads. In other words, there is a LOT more space in the compressed combustion chamber in a 540-inch horizontal six than a 350-inch 8 cylinder 'V' engine. The compressed chamber volume in a V-8 can be less than 50cc, wheras the compressed chamber volume in a Lycoming 540 is over 100cc. Not to mention the complete lack of a quench area in the Lycoming, and static compression under 8:1 (how else could you run 90LL at those altitudes?). It's a little different game.
But still a good observation...
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
MSD Ignition bad with platinum plugs (or any precious metal plug)
It will mess everything up. Even the mistake, LS-1 Camaros come with a coil per cylinder and platinum plugs, just by changing the plugs and reseting the computer they run much better. Dont ask...
Car: 99 Formula
Axle/Gears: 342
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
