Won't start.
Old Feb 27, 2002 | 10:13 AM
Petrella's Avatar
Won't start.
Just replaced the carb. and put in a non cc distrubutor and won't start. I got #1 tdc dropped in the dis. still nothing. Checked to see if it was getting spark and it is. My cc one has 2 wire plug which mathces to the non cc that plugs into the coil. the cc also has a 4 wire plug that the non cc does not have. Do I have to slice into the 4 wire plug and hook it somewhere on the non cc? Thanks Petrella.
Old Feb 27, 2002 | 11:29 AM
Vader's Avatar
Petrella,
Are you still using the ECM? It expects to see some reference pulses from the distributor before it will enable soem functions, but if you are getting spark, aall you need after that is fuel, compression, and the correct timing.
The ECM connections are like this:
Old Feb 27, 2002 | 12:03 PM
Petrella's Avatar
Vader,
I'm still kinda confused, am I going to have to cut into the 4 plug coming out of the wiring harness and tap it into the plug going out of the dis.? I am new at this, can you explain in detail please. Thanks again Petrella
Old Feb 27, 2002 | 12:39 PM
Vader's Avatar
Like I asked, are you still using the ECM for anything?
Old Feb 27, 2002 | 12:47 PM
Petrella's Avatar
Vader,
I don't even no what the ecm is or used for so I can't really answer that question. Sorry like I said I'm new at this. All I can tell you is when I put the non cc dis in and hook everything up I have a 4 plug wire left over that comes out of the harness.
Petrella.
Old Feb 27, 2002 | 01:18 PM
Vader's Avatar
Petrella,
For your installation, you'll need to make sure you have the HEI module connected correctly. Your older style didtributor should have a module with only four wire connections. The last connection is the ground, of course, and the ground is accomplished through the mounting screws.
The four terminals should be marked 'B', 'C', 'W', $ 'G'. the 'B' terminal should have a 12VDC positive supply whenever the ignition is ON. The 'C' terminal connects to the positive end of the ignition coil primary. The 'W' and 'G' terminals connect to the pickup coil in the base of the distributor, and are keyed by the size terminals used. If all that is correct, the coil should provide spark.
Old Feb 27, 2002 | 01:44 PM
Chevy83Z28's Avatar
If you changed the carburetor and the distributor, and you're getting spark, would that sort of limit the problem to the carb? Maybe it's not set right or not supplying fuel. You sure the timing's not too far off to get the car running? ... Just some ideas sorry if they're off...
Old Feb 27, 2002 | 01:46 PM
Petrella's Avatar
Vader,
ok I understand now what you are tell me. Thanks for all the help. let me ask one last thing. will I lose anything performance if I just use the cc dis.? Thanks again. Petrella.
Old Feb 27, 2002 | 01:48 PM
Petrella's Avatar
Chevy83z28,
I was getting spark when I dropped the non cc dis. in but it would not start. when I dropped the cc dis. back in and hooked up all the wires it firing right up.
Petrella
Old Feb 27, 2002 | 03:06 PM
Chevy83Z28's Avatar
oh..then maybe its in the distributor somewhere sorry i dont know much about the right way to hook it up though.
Old Feb 28, 2002 | 08:47 AM
Vader's Avatar
Petrella,
You may not lose a lot of power, but probably will lose some fuel mileage with the standard HEI distributor.
RS Reaper
Oct 17, 2018 07:52 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
Jlanz55
Sep 29, 2015 08:55 AM
