Best way to put cam gear on the crank...
Old Mar 3, 2002 | 02:36 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I read I shouldn't use a hammer to put it on. I have before but it always involved a block of wood and tapping.
Maybe this time I should BBQ the cam gear before I install it? Maybe cook the gear and ice down the crank snout?
Old Mar 3, 2002 | 03:07 PM
Vader's Avatar
Astro,
You could heat the sprocket with a bearing heater, then quickly push it in place. There are also installation tools available, but a large (1½) socket, a pulling stud, nuts and washers works pretty well, too. Thread the stud fully into the crank snout. Lightly lube the crank sprocket bore, then start the sprocket straight. Slide the socket over the stud, install a flat washer and nut, and slowly pull the sprocket into place with the nut.
Using a hammer and soft drift will probably not damage the sprocket, and probably can be done safely if you don't get "wicked" with the hammer. However, there is a risk of damaging the thrust bearing surfaces of the crank if the hammer gets a little too "active".
Old Mar 3, 2002 | 04:17 PM
kevinc's Avatar
Car: 1982 Z28
15 minutes at 400deg in the oven usually does it for me, going straight from the oven to the crank and it slides right on.
Old Mar 3, 2002 | 04:32 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Spatchula, tongs, or gloves?
AJ
Old Mar 3, 2002 | 05:26 PM
rezinn's Avatar
Gloves, they will not absorb heat as quickly so it will stay hotter. Just run it out to the garage real quick and get it on there, as soon as it touches the crank it will cool off very quickly and start shrinking.
Old Mar 3, 2002 | 05:44 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Thanks for the tips
Old Mar 4, 2002 | 07:49 AM
Vader's Avatar
Astro,
I just re-read the post. You might not want to put the cam gear on the crank, unless you're doing something really special....
Old Mar 4, 2002 | 03:06 PM
Car: Bee-Bowdy
Axle/Gears: fo-tins
Hehehehe....NAYSAYER!!
j/k
You get the idea...thanks for the tips.
eightsixseven
Dec 16, 2024 01:50 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
jklein337
Sep 19, 2018 06:23 PM
camaro71633
Sep 1, 2015 10:24 AM
86White_T/A305
Aug 17, 2015 12:16 AM
