I wanna get the MSD 8.5mm SC wires but...
Old Mar 9, 2002 | 08:34 PM
ChevyLuva3's Avatar
I want to purchase the MSD 8.5mm wires, for my 89 IROC, but I don't see wires specifically made for my car??? When I look at the pricing for each car, I don't see mine mentioned. Which ones should I get? I sure as hell don't want to crimp them all and ****. Help me out, should I just call the d@mn MSD service? Thanks!
Old Mar 9, 2002 | 08:59 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i have a 91 bird and they dont list specifically for mine either......call summit theyll set ya up with something real close...mine were from a truck tbi motor listing......their a little longer ...i just curled em behind the distributor...no biggie
Old Mar 10, 2002 | 01:10 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Get the ones specified for the TPI vette app. (same motor). Those are the ones i have and the fit and work just fine.
Old Mar 10, 2002 | 10:09 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Crimping them isn't a hard job... it just sounds like a pain.
Old Mar 10, 2002 | 10:56 AM
88TAJeff's Avatar
Car: 88 T/A
TomP is right, crimping them isn't hard at all. If you get some extra long wires, you can route them over the valve covers, and away from the manifolds.
Old Mar 10, 2002 | 12:42 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I had issues with the p/n's that Summit was giving me, so I just called up MSD and specified what I wanted. Be sure to tell them if you want anlged or straight boots (in relationship to your manifolds/headers).
Old Mar 11, 2002 | 09:41 AM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I had the same problem with my car when I ordered mine. Summit or Jegs can help you out. Be prepaired for a tight fit if you go with the ones made for your car. They are cut with little slack, I had to rig mine up a little on the driver side to keep them off the manifold.
Old Mar 11, 2002 | 09:50 AM
wasp's Avatar
i went with all ninetys after i burned up the straights
BRoss99
Aug 10, 2025 05:08 PM
stalkier
Dec 6, 2015 11:25 PM
overdriv
Aug 20, 2015 03:52 PM
penguinpanda0
Aug 15, 2015 06:45 PM
midias
Aug 15, 2015 05:07 PM
