Do the electronic speedometers read off of the computer or the speed sensor??
Old Mar 10, 2002 | 06:10 PM
CamaroX84's Avatar
I am switching my entire dash out for the 90-92 style dash in my Camaro. I am running a 90-92 ECM and I have a speed sensor. To make the speedometer work, does it read off of the computer or the Vehicle Speed Sensor (VSS)? Thanks in advance.
Old Mar 10, 2002 | 07:51 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Do the electronic speedometers read off of the computer or the speed sensor??
the computer reads the VSS sensor then send to the dash. so to answer te question, the speedo works off the signal from the computer.
Old Mar 10, 2002 | 10:56 PM
CamaroX84's Avatar
Are there any modifications I need to do to the dash to make it work? I know I had to modify my 84 dash harness to work with the 90-92 TPI computer. But now I'm switching over to the 90-92 dash. Any ideas? Thanks.
Old Mar 11, 2002 | 07:02 AM
JeffC1500TBI's Avatar
hmm... my '88 p/u seems to go directly to the dash or something.. at least I know to recalibrate for the different tires it was done on the rear of the dash.. also when I run the winaldl it won't show me the speed.. any input on this one?
Old Mar 11, 2002 | 09:52 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
mmmmmmmmmm my 91 bird reads off a set of plastic gears in the tranny tail cone............
Old Mar 11, 2002 | 01:19 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Hey Jeff The gauges for the 88 to 91 trucks have the vss buffer built into them. The vss signal is first sent to the gauges and from there it is converted to a signal the tbi computer can understand.
As for why winaldl wont display speed for you I would have no idea.
Also if you have not switched to the 91 gauges with a tach. but would like to let me know and I will send you the wire diagram for the swap, it is the easiest swap possible.
Old Mar 11, 2002 | 04:55 PM
mrr23's Avatar
Engine: 360 HSR
i could be wrong. i'll check my wire diagrams for my '86 ta. it is electronic speedo.
Old Mar 12, 2002 | 03:27 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I too have a 90-02 ECM in my car.
I am still running the VSS Buffer box that was stock on my car.
One day I will run it through the ECM since the ECM uses the VSS Data for some things.
eightsixseven
Dec 16, 2024 01:50 PM
9192camaro
16
Feb 3, 2019 12:21 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
