gas dripping out of headers?????
Old Mar 12, 2002 | 08:41 AM
88_RS&86_Z-28's Avatar
its a non thrid gen ? but......
my friends mustang is dripping out gas from the headers why is this i have never seen this happen to anything???????
could it be cuz some cyld. are not firing or what to weird man.
Old Mar 12, 2002 | 08:51 AM
jdrobley's Avatar
gas dripping from the exhaust is usually not enough air flow or too much gas. It usually isn't spark related because the atomization and engine pumping air through it usually clears itself out pretty good.
Air flow - Extreamly dirty air flow or plugged exhaust.
Fuel - Flooding carb or injectors stuck open.
We would need more info to accuratly diagnose the problem.
Jess
Old Mar 12, 2002 | 09:07 AM
ok so either he is not getting enough air which he does have a small air cleaner on it. so if he took that off and it still did it then that would me its flooding from the carb right?
plugged exhuast i dont think it is because its open headers. or that is if i understand what you meant by that one
it is a carb eld. i think 600cfm but i know he has a holley fuel pump elc. so then we could stop or slow that down with a FPR right?
Old Mar 12, 2002 | 09:20 AM
jdrobley's Avatar
by plugged exhaust, i meant the catalytic converter.
with that elec fuel pump, it could be putting out too much pressure and overpowering the float. find out the pressure of the pump which should be about 6 to 10 lbs for a carb. if that checks out, check your float level. year and make of car? a afpr may be your answer. check it out first.
jess
Old Mar 12, 2002 | 09:28 AM
Alright thank you so very much thats where we will start and its a 82 rustang with a 302 somthing only the stock 305 camaros would have to worry about :sillylol: sorry i had to
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
