Car's in shop. Questions...
Old Mar 14, 2002 | 12:59 PM
1BadGTA's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 Liter
Okay here it goes. I replaced my car battery last saturday, and then right after that, when I'd come to a stop, my car would stall out sometimes. Thinking it was my alternator, I got it checked, and I'm getting a good charge from the battery and alternator. Nothing wrong. Then last night I shut my car off, and I could smell gas fumes. I'm at a loss. Anyone have any idea what it could be?
thanks
Old Mar 14, 2002 | 01:55 PM
Chevy83Z28's Avatar
When the car was stalling out what made you connect that to the voltage system? It could be a number of things you need to post more info I think... is it carbed? If so that may be the first place to look... especially if you're smelling gas.
Old Mar 14, 2002 | 04:12 PM
1BadGTA's Avatar
Engine: 5.7 Liter
Whoops, should have explained that a little better. It's my '92 bird 3.1 V6 EFI. This guy at the Pontiac dealership checked out the alternator, which is where I thought the prob was coming from. I'm at a loss.
Old Mar 15, 2002 | 08:20 AM
1BadGTA's Avatar
Engine: 5.7 Liter
Okay, here's what the shop told me. My throttle bottle is badly carboned up which is causing the car to stall when I stop. Also the IAC sensor is pretty shot too. They told me it would cost about $500 to have the throttle body cleaned out (time/labor). My question is this, how hard is it to remove the throttle body and clean it myself? The only other option is to buy another one because I'm not spending $500+ to flush out carbon, that's rediculous.
thanks
Old Mar 15, 2002 | 09:00 AM
cfabe's Avatar
$500 is way way too much for cleaning the throttle body. At dealer shop rates thats still like 7 or 8 hours of labor. I'm not totally familiar with the v6 tb but surely it cant take more then an hour or 2 max to remove, disassemble, clean, and replace.
Old Mar 15, 2002 | 09:26 AM
Vader's Avatar
You may not have to even remove the TB. Remove the intake hose/ductwork and manually open teh throttle valve. Using spray cleaner (safe for EFI/sensors) clean all exposed areas, including the IAC ports. You may want to remove the IAC stepper motor (NOT "sensor") and clean the pintle and recess in the TB. The whole process may take an hour.
If you haven't adjusted the throttle valve position, you shouldn't have to do anything else after you finish.
Old Mar 15, 2002 | 10:05 AM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
check the fuel pump
Old Mar 15, 2002 | 11:01 AM
1BadGTA's Avatar
Engine: 5.7 Liter
Thanks for the help guys. As for the cleaner, all I've been able to find is carb cleaners. What's a good cleaner to use? And as far as the IAC stepper motor, does this just get sprayed off with a cleaner as well?
thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
