HEAD LIGHTS won't flip up sometimes...
Old Mar 17, 2002 | 01:45 AM
TBIWorks's Avatar
It is an intermitant problem. Eventually they will work if I keep trying them. Is this a common issue in the third gen firebirds? If so what is it, if it isn't a headlight motor, or is it that?
Old Mar 17, 2002 | 08:34 AM
Vader's Avatar
TBI,
Is it one headlight that won't open, or both of them that refuse to move when they hang up? If it's only one, it narrows down the possibilities. If both fail to open at the same time, you may have a different problem involving the isolation relay.
Old Mar 17, 2002 | 10:26 AM
TBIWorks's Avatar
it is both that bo it together, What is that relay and wher is it? Also are there 2 healight motors or one?????
Old Mar 17, 2002 | 06:52 PM
SLOW91TA305's Avatar
I had the same problem with my 91 TA. One light wouldn't come up sometimes. I would flip the switch a few times to get it up. The problem was a plastic gear that stripped and plastic ball bearings that got ground up into powder in the light assembly motor. Yes, there is a motor for each light. (thats the assembly with the lil black ****)
Here is a link to instructions I used to fix my problem...
http://www.shsu.edu/~stdvjs11/headli...ightmotor.html
(Definatly replace the ball bearings with reliable metal ones)
hope it helps
Old Mar 17, 2002 | 10:05 PM
TBIWorks's Avatar
It is both that do it together, so it isn't a motor, it must be a relay, does anyone know where it is located???
Old Mar 18, 2002 | 12:56 AM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
There is a module for the lights right next to the brake booster. I had to replace it on my 89 GTA. They arent cheap...about $150. Luckily I got mine for $20. Anyway, is has 2 long plugs...one with 4 wires, the other has 5 wires. Try that.
Old Mar 18, 2002 | 01:45 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Shoulda got a Camaro
Old Mar 18, 2002 | 09:45 AM
Vader's Avatar
TBI,
There are two motors for the headlight doors. There is a motor actuator relay at each front corner (for each motor). There is also an isolation relay with a yellow, black, pink, white, dark blue, and dark blue/white wire on the terminals. This may be located under the hood on some years or in the driver's footwell/firewall area inside the car.
TBIWorks's Avatar
I own a camaro, wanna buy it, it is real nice. I didn't mean to buy a pontiac, but it was so sweet looking....
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
Omega
Aug 10, 2015 12:46 PM
