Aftermarket ignition + aftermarket spark plugs?
Old Mar 17, 2002 | 03:58 PM
LeftTurn1LE's Avatar
Can someone explain why this is not a good combination. What are the problems and causes? Why are performance plugs recommended for use with stock ignition only?
Old Mar 18, 2002 | 08:34 AM
Vader's Avatar
LT1LE,
Who is recommending aftermarket plugs with stock ignition only?
Old Mar 18, 2002 | 11:02 AM
rezinn's Avatar
If a company says to only use their plugs on stock ignition, I wouldn't buy them because they are probably crap.
Old Mar 18, 2002 | 12:15 PM
Sorry guys , maybe I am mistaken. From everything I have read on here before about mixing AC Rapidfires with MSD stuff I am confused.
Old Mar 18, 2002 | 10:15 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
My rapidfires had instructions right in the box saying they were for stock ignitions only. I tried them with my msd6a and jacobs coil. ran like crap. Used the same set with my stock ignited chevelle and they work fine.
Old Mar 19, 2002 | 12:51 AM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
I don't know much about spark plugs, just that when I replaced them with a regular set of bolts, the engine didn't run?
They're just there to plug that hole right?
Just kidding.
But really, I am running rapidfires with my new Crane Hi-6 (and stock coil for now) and it runs fine. Are there greener pastures with other plugs or what.
I have noticed though that at night, I can see the ceramic insulators on the plugs glowing with the spark pulses. It kinds worries me. This can't be normal.
Old Mar 19, 2002 | 01:27 AM
Blackened's Avatar
I have RapidFires and full MSD ignition. Works fine for me ?!?
Old Mar 19, 2002 | 09:01 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
The jacobs ultracoil is a variable voltage/amperage unit. It uses the spark plug as a resistance sensor. This is probably why I had so much problem with them. It's calibrated for normal copper plugs. The main reason I responded to this post was because of the instructions that came with my rapidfires. These weren't bubble packed rapidfires but ones in the cardboard box. And they did say stock ignition only, plus the "don't re-gap" crap.
Old Mar 19, 2002 | 09:25 PM
yeah, thats what I thought. The rapidfires say for use with stock ignition, and some people have had trouble. What I want to know is why this happens. Is this only a problem with platinum plugs? Is it only with AC Rapidfires? Basically, what kind of compatibility issues do I need to know when buying spark plugs, plug wires, modules etc.?
Old Mar 20, 2002 | 09:11 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
One more thing. I tried splitfires once and they worked fine. Maybe even helped a little bit. However, once they were worn I never bought another set. If they really did do something it wasnt enough to be worth the money.
Old Mar 21, 2002 | 01:17 PM
I agree. I'm not planning on buying any expensive plugs either. I just wanted to know why certain plugs can't be used with certain iginition. All my plugs are fouled from previous problems which are now fixed. I will either replace them with standard AC Delcos or some NGKs. I have Accel 8.8mm spiral-core wires.
Old Mar 21, 2002 | 08:37 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use a Holley Anihilator ignition system, MSD 8.5 wires and plain ordinary AC R43TS plugs. I have them gapped at .050"
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
