How can you tell if your timing chain "slipped" stretched?
Old Mar 21, 2002 | 01:18 PM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
I still haven't solved my high RPM miss problem....I even swapped in a new distributor, new plug wires, different carb.....a friend of mine was saying that it could be a slipped timing chain. Come to think of it, back when I swapped my vortecs on my motor (bout a year ago) I used a crappy single row autozone style chain (doh!). how would the motor run with a stretched chain?
Chris
Old Mar 21, 2002 | 01:34 PM
Camaro_hunter_d's Avatar
Re: How can you tell if your timing chain "slipped" stretched?
Chris
If your timing has changes... BINGO. If not its not the chain. did you check your EGR?... thats a high speed miss kinda prob. Does not open/close fully. causes many a probs.
Old Mar 21, 2002 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Use a timing light and watching the timing marks jump all over the place is usually a good indication of a stretched chain. A stretched chain will still run since ignition timing can be adjusted but cam timing will be off.
The chain won't slip causing a high rpm miss. If it slips the engine won't run.
Check your fuel system. Change the filter. If you can, install a pressure gauge and observe the fuel pressure at high rpm.
Old Mar 21, 2002 | 08:53 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
well, you can get some timing fluctuation from a worn dist gear
with the valve cover off, turn the harmonic bal backward. How far does it go b4 the valves move.
Thats just a swag way.
Old Mar 21, 2002 | 09:40 PM
2vmodular's Avatar
no need to remove the valve cover, just pulling the distributor cap is a lot easier. distributor is driven off cam gear, so turn harmonic balancer and observe how long it takes before rotor starts to turn.
Old Mar 21, 2002 | 09:51 PM
Car: Junk
Motor has no EGR. Read my sig. Well I replaced the distributor and although the problem "somewhat" went away, it still doesn't pull really hard past 5 grand like it used to......I checked the timing and its right on the money..however it DOES jump around a little, but JUST a little.....anyways the motor is being dissassembled tommorow in preperation for the new race ported vortecs, timing chain, Super Victor intake, and 1.6 RR next week. Funny thing will be when I start the car up again after all the new parts are installed and it still has a high RPM. Then I think I'll just sell the car and buy a Honda!! HAAHAHAHA right..........
Chris
Old Mar 22, 2002 | 03:22 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
slipped chain is easy
it sounds like this
tick tick BOOM
as far as a streched chain can't you find how much play it has?
there are specs for that right?
and as CHD said if your timing is off and you replaced all your ign stuff already and you still have the problem then I think it might be it
though how much work is it to put in a roller system rather then a chain?
are they worth it?
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
