Air-line to Cat critical?
Old Mar 23, 2002 | 10:23 AM
JAF's Avatar
JAF
Is the airline from engine to catalytic converter important? The previous owner of my TA cut the line and closed it off when the cat was removed. I have since installed a Catco 3" converter.
Old Mar 23, 2002 | 11:14 AM
bobkaq's Avatar
I believe that hose brings exhaust back in to the combustion chamber to be reburned. I dont have it on mine, I dont think its necessary.
Old Mar 23, 2002 | 11:49 AM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i ripped it out along with the cat , the air pump, the air tubes,etc etc
Old Mar 23, 2002 | 12:05 PM
mattRS's Avatar
from my understanding, that tube goes to the tubes going into your exhaust manifolds. exhaust goes from the cat BACK into the exhaust so it can go through the cat again and make the air cleaner...not really important, especially if you have aftermarket headers.
Old Mar 23, 2002 | 12:09 PM
rhuarc30's Avatar
Umm okay guys, last I checked that pipe was part of the AIR system. It pumps air into the cat to improve the efficieny by providing more oxygen to the process. It also helps keep the cat from being to hot. But if you are running an aftermarket cat, no cat, or hollowed cat, it's not important unless your in a place where they look to see if all the emissions gear is in place.
Old Mar 23, 2002 | 12:12 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
should be to bring air from the airpump to the cat to help burn the unburnt gas inside there.
without it you stand a chance the unburnt fuel to clog up the cat
Old Mar 23, 2002 | 12:46 PM
bobkaq's Avatar
Thank you for correcting my incorrect staements.
Old Mar 23, 2002 | 03:48 PM
topdown's Avatar
That air tube acts as a vent to reduce backfiring. It uses the air pump to reduce pressure build up. Not a necessary item.
Old Mar 23, 2002 | 04:13 PM
camaro6spd's Avatar
ummmm it brings O2 to the cat...also, if it reduced backfireing then i dunno about you but i woul keept it there, i don't like a backfiring POS
Old Mar 23, 2002 | 04:34 PM
topdown's Avatar
Agreed--but I wouldn't go out of my way replacing a missing one unless I was having issues. I've removed them while removing the cat before and I had occational backfire(not really loud) when engine was cold..but that was in part do to a better flowing exhaust resulting in reduced backpressure. I never had related backfire problems once the engine warmed up.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
