major problems!!!
Old Mar 24, 2002 | 09:38 PM
SCOTTCAMARO1's Avatar
major problems!!!
ok im haveing trouble...my car has been running rich and surgeing at cruiseing speeds....tonight we were checking i out,when you hold the brake and drop it in gear,the motor revs to about 1400 rpm....when im just sitting still,i put it in park and it jumps to 2500.....but i shut it off and start the car and it idles fine.....im soo lost......
Old Mar 25, 2002 | 12:04 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Not sure on the richness, but the idle and surging problems could be related to the IAC valve and it's passage in the TB. Pull it out and clean it and it's passage thoroughly and see if that helps the idle. Do you have any scantool data or DTCs from the car? A little more info on the application would help us help you as well.
Matt
Old Mar 25, 2002 | 11:53 AM
Vader's Avatar
What engine? What year? What fuel system?
Old Mar 25, 2002 | 11:00 PM
its a 92 lo3
Old Apr 1, 2002 | 04:33 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
Major Problems too!!!!
I have had similar problems with hesitation where the car jumps. Replaced fuel filter, vacuum hoses, MAF sensor, O2 sensor, spark plugs and wires, pcv valve, cleane3d out throttle body, put new intake manifold gaskets on too. It still kinda jumps at any speed when i slightly press the gas pedel. The injectors were cleaned also and i can't seem to fix the problem. If you find out let me know please!!
Old Apr 1, 2002 | 05:27 PM
Vader's Avatar
What is the TPS setting? Is the TPS steady through the entire operating range?
Old Apr 1, 2002 | 10:19 PM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
I also had the hi rev problem for a while they replaced the coolent sensor which stopped the veh from going into a closed loop after warm up and the iac valve which was malfuncting. Its been running pretty good since
Old Apr 2, 2002 | 07:26 PM
TrnsmGTA's Avatar
Car: 87 Trans Am
TPS
How do i check or adjust the TPS, is that the cable attached to the throttle body that you push the side button in and it goes in or out, what should it be?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
andy74
Sep 3, 2015 08:41 AM
Jackrabbit501
Sep 2, 2015 09:14 PM
mrdevontay
Sep 2, 2015 08:04 PM
greenyone
Sep 2, 2015 03:39 PM
